Oh no! Lost oil pressure ... |
SirAndy |
Feb 15 2018, 08:38 PM
Resident German Group: Admin Posts: 41,648 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Got stuck in traffic on my way home from work today and didn't notice the oil light until the engine started making horrible noise.
Did the only thing i could think of which was to pull onto the side strip and get on the gas hoping to get oil pressure back. That actually worked! Pressure went back up to ~80 under load and ~30 at idle for the rest of the drive home but i'm afraid i might have done some permanent damage. By the time i noticed the engine noise and the pressure being at zero i was probably already running completely dry. (IMG:style_emoticons/default/headbang.gif) Now the real question is, how the heck did that happen? I checked the oil after i got home and it's still all in there. All 16 quarts of it. Could there be a blockage somewhere? Stuck piston? Clogged filter? (IMG:style_emoticons/default/sad.gif) |
IronHillRestorations |
Feb 17 2018, 07:18 PM
I. I. R. C. Group: Members Posts: 6,719 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Do you have braided stainless oil lines? If so I'd recommend checking all the oil lines. I've seen those things internally collapse closed, and the outside of the hose looked perfect.
SirAndy |
Feb 17 2018, 10:21 PM
Do you have braided stainless oil lines? If so I'd recommend checking all the oil lines. I've seen those things internally collapse closed, and the outside of the hose looked perfect. The only braided line is the shot hose from the tank to the hardline going to the engine. (IMG:style_emoticons/default/idea.gif) |
Lo-Fi Version | Time is now: 19th May 2024 - 03:51 PM |
