Oh no! Lost oil pressure ... |
SirAndy |
Feb 15 2018, 08:38 PM
Resident German Group: Admin Posts: 41,648 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Got stuck in traffic on my way home from work today and didn't notice the oil light until the engine started making horrible noise.
Did the only thing i could think of which was to pull onto the side strip and get on the gas hoping to get oil pressure back. That actually worked! Pressure went back up to ~80 under load and ~30 at idle for the rest of the drive home but i'm afraid i might have done some permanent damage. By the time i noticed the engine noise and the pressure being at zero i was probably already running completely dry. (IMG:style_emoticons/default/headbang.gif) Now the real question is, how the heck did that happen? I checked the oil after i got home and it's still all in there. All 16 quarts of it. Could there be a blockage somewhere? Stuck piston? Clogged filter? (IMG:style_emoticons/default/sad.gif) |
Dave_Darling |
Feb 18 2018, 06:45 AM
914 Idiot Group: Members Posts: 14,986 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Since we're guessing:
A piece of paper towel got into the tank and wound up across the pickup. It finally dislodged and things are back to normal for now. The loss of pressure caused the hydraulic lifters to hammer the valve tips, caused the piston skirts to scuff the cylinder walls, and put a lot of wear on your bearings. Of course, if you drained the oil and checked the filter, you could get some idea of what is actually going on, but until then we can keep speculating and telling you it's all doom and gloom.... --DD |
SirAndy |
Feb 18 2018, 10:57 AM
A piece of paper towel got into the tank and wound up across the pickup. It finally dislodged and things are back to normal for now. The loss of pressure caused the hydraulic lifters to hammer the valve tips, caused the piston skirts to scuff the cylinder walls, and put a lot of wear on your bearings. Funny you should say that, i am missing a shop towel that was tucked away in the engine bay ... (IMG:style_emoticons/default/idea.gif) |
Lo-Fi Version | Time is now: 19th May 2024 - 06:34 PM |
