Oh no! Lost oil pressure ... |
SirAndy |
Feb 15 2018, 08:38 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Got stuck in traffic on my way home from work today and didn't notice the oil light until the engine started making horrible noise.
Did the only thing i could think of which was to pull onto the side strip and get on the gas hoping to get oil pressure back. That actually worked! Pressure went back up to ~80 under load and ~30 at idle for the rest of the drive home but i'm afraid i might have done some permanent damage. By the time i noticed the engine noise and the pressure being at zero i was probably already running completely dry. (IMG:style_emoticons/default/headbang.gif) Now the real question is, how the heck did that happen? I checked the oil after i got home and it's still all in there. All 16 quarts of it. Could there be a blockage somewhere? Stuck piston? Clogged filter? (IMG:style_emoticons/default/sad.gif) |
porschetub |
Jun 6 2018, 09:48 PM
Advanced Member Group: Members Posts: 4,703 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Come on whats the deal just no info since the issue,fess up (IMG:style_emoticons/default/biggrin.gif) ,don't think its bad oil with viscosity issues unless an injector puked and spat leaking raw fuel into the motor,this isn't a common problem but I don't know these motors much.
Did you have hyd tappet noise previous to shutdown ???. Tried all those old mothers remedys but atf ,kerosene ,diesel ....good luck on that might have been ok on some old 1960 engine but not in this case. Hope you get it sorted without $$$$$,good luck Andy. |
Lo-Fi Version | Time is now: 30th May 2024 - 09:07 AM |
