Oh no! Lost oil pressure ... |
Feb 15 2018, 11:13 PM
Park it, finish up the house projects.
Feb 15 2018, 11:15 PM
Resident German Group: Admin Posts: 41,625 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Well, i just did some reading and apparently it's pretty common for the lifters to gunk up and collapse.
(IMG:style_emoticons/default/huh.gif) |
Krieger |
Feb 15 2018, 11:31 PM
Advanced Member Group: Members Posts: 4,705 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
What damage have those motors seen. So what is the solution? Teardown? A couple of oil changes?
76-914 |
Feb 16 2018, 08:50 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,495 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Well, i just did some reading and apparently it's pretty common for the lifters to gunk up and collapse. (IMG:style_emoticons/default/huh.gif) Well, that’s good news; I think. Weird. Anyway, glad it fixed itself. You don’t need a rebuild on top of a remodel. (IMG:style_emoticons/default/beerchug.gif) |
Feb 16 2018, 10:04 AM
914 Idiot Group: Members Posts: 14,982 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
You're just guessing until you start examining stuff. The first step is to open up the oil filter and see if there is any metal trapped in it.
--DD |
Feb 16 2018, 11:05 AM
You're just guessing But that was sort of the point of this thread, i want people to guess so i can cover more possibilities. There are many people on here that know a lot more about /6 engines than i do ... (IMG:style_emoticons/default/shades.gif) |
Feb 16 2018, 11:18 AM
914-6 GT in waiting Group: Members Posts: 19,258 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
You're just guessing But that was sort of the point of this thread, i want people to guess so i can cover more possibilities. There are many people on here that know a lot more about /6 engines than i do ... (IMG:style_emoticons/default/shades.gif) See post #2. It can be a lot of things but the oil filter will tell you a lot with very little effort. If you see gold, you will know to pull the engine for a rebuild. No other search needed. If the oil looks clean, then step 2. |
Chris914n6 |
Feb 16 2018, 01:22 PM
Jackstands are my life. Group: Members Posts: 3,316 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
3.6L right? Hydraulic lifters? Hydraulic cam guides? What do you think the noise was? Doh, yes, could it be that the lifters ran out of oil??? (IMG:style_emoticons/default/idea.gif) Lifters are at the end of the supply chain, so it's likely what you heard. Sounds like tapping an unsharpened pencil on a desk. Doesn't explain the pressure loss though. Since it recovered I'd check for sludge buildup somewhere. Cutting the filter open is still a good idea. It will answer the bigger questions. |
914dave |
Feb 16 2018, 01:43 PM
914 Addict Group: Members Posts: 700 Joined: 19-October 03 From: Willow Grove Pa. Member No.: 1,262 Region Association: North East States |
bulitt |
Feb 17 2018, 06:43 AM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
No smoke out of the tailpipe means your rings are still good..
JOEPROPER |
Feb 17 2018, 07:19 AM
The answer is "no" unless you ask... Group: Members Posts: 1,184 Joined: 21-November 15 From: White Plains New York Member No.: 19,387 Region Association: North East States |
I don't know if these engines are prone to sludge, but most people change engine oil on collector / hobby cars way before it's due. I don't put that many miles on my car each year, so it doesn't get away from me. Hopefully it's an easy fix. I'd cut the filter open and take a look first because it's the easiest thing to do.
PanelBilly |
Feb 17 2018, 10:15 AM
914 Guru Group: Members Posts: 5,804 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
Maybe send the oil out for analysis. That’s not too expensive
ConeDodger |
Feb 17 2018, 10:39 AM
Apex killer! Group: Members Posts: 23,579 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Well, i just did some reading and apparently it's pretty common for the lifters to gunk up and collapse. (IMG:style_emoticons/default/huh.gif) Paul Sayeh had a couple collapsed lifters when he first got his 3.6 from LA Dismantlers. And we all know how that turned out... (IMG:style_emoticons/default/evilgrin.gif) |
Elliot Cannon |
Feb 17 2018, 10:43 AM
I got one of these to cut open the oil filters on my Cessna 150 but I also use it for my car. I cut it open, slide a strong, slim magnet between the folds of the filter. I then cut out the filter paper, unfold it, take it out in the sun and check for shiny bits. If you want to borrow mine, I'll ship it up to you. http://www.aircraftspruce.com/catalog/topa...p?clickkey=4975
Elliot Cannon |
Feb 17 2018, 10:50 AM
You can also send a sample to these guys. I know, this is airplane stuff but it's still an air cooled boxer style horizontally opposed engine. I have airplane oil checked every oil change every 25 hours. I know that sounds like over-kill but if my engine has trouble, I can't pull over and stop on the side of the road. (IMG:style_emoticons/default/av-943.gif) http://www.aircraftspruce.com/catalog/eppa...lickkey=3058045
mb911 |
Feb 17 2018, 12:06 PM
914 Guru Group: Members Posts: 6,833 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Andy my concern is that the lifters don't have much to do with oil pressure as the pressure is measured prior to that point..
IronHillRestorations |
Feb 17 2018, 07:18 PM
I. I. R. C. Group: Members Posts: 6,716 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Do you have braided stainless oil lines? If so I'd recommend checking all the oil lines. I've seen those things internally collapse closed, and the outside of the hose looked perfect.
wndsrfr |
Feb 17 2018, 09:21 PM
Senior Member Group: Members Posts: 1,428 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
OK, 'nother thought....is there a pinhole leak in your cooler such that when the thermostat kicked the oil pressure dropped out for a bit?
Tdskip |
Feb 17 2018, 09:38 PM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
QUOTE See post #2. It can be a lot of things but the oil filter will tell you a lot with very little effort. If you see gold, you will know to pull the engine for a rebuild. No other search needed. If the oil looks clean, then step 2. I think this is really good advice. Having had a similar experience there's a risk of chasing anything and everything without getting to ground truth. Getting a lab to let you know what's in the oil is also a really good idea I think. My fingers and toes are crossed for you that that the filter is clean. |
Feb 17 2018, 10:20 PM
Andy my concern is that the lifters don't have much to do with oil pressure as the pressure is measured prior to that point.. I know the two aren't related, there is/was obviously also a blockage somewhere ... (IMG:style_emoticons/default/idea.gif) |
Lo-Fi Version | Time is now: 8th May 2024 - 06:49 PM |
