MPS Certificate, slow leak ?? |
MarkV |
Jul 9 2003, 08:42 PM
I just got my wiring harness & MPS back from Jeff Bowlsby. Jeff tested my MPS & made some repairs to my harness. Jeff did a great job on the harness. (IMG:style_emoticons/default/pray.gif)
The MPS passed all of the tests except for the leak down test. The standard leak down is from 40 cm/Hg in 4 minutes, mine leaked down in less than 2 minutes. I was wondering if I should take it apart to try to fix the leak, or just run it. It's a sealed MPS that appears to be a rebuild. (IMG:style_emoticons/default/confused24.gif) Attached thumbnail(s) |
ChrisReale |
Jul 9 2003, 10:40 PM
I would not mess with it. All it will do is run rich, and in your case, not too bad.
Bleyseng |
Jul 10 2003, 08:13 AM
Which looks like that might be good to run rich cuz the calibration is a little lean for my taste.
Geoff |
MarkV |
Jul 10 2003, 02:52 PM
QUOTE(Bleyseng @ Jul 10 2003, 06:13 AM) Which looks like that might be good to run rich cuz the calibration is a little lean for my taste. Geoff Too lean to run on a stock cam 2056?? (IMG:style_emoticons/default/confused24.gif) |
Lawrence |
Jul 10 2003, 04:01 PM
QUOTE Ok, I give away the secret settings here For a 2056cc you need at 0hg (WOT) about 1.50 -1.55 At 4hg (partload ) you need 1.26-1.28 At 15hg (idle) you need .74-.77 This gives you the proper A/F mix at partload about 13.7 to 1 and at WOT about 12.5 to 1 Write it down cuz this message will self destruct in 12hrs. Geoff Saved for posterity. (IMG:style_emoticons/default/smile.gif) |
MarkV |
Jul 10 2003, 04:04 PM
So Geoff, can I send it to you? For a fee of course. (IMG:style_emoticons/default/w00t.gif)
Bleyseng |
Jul 10 2003, 04:08 PM
Yeah, I can adjust it for you.
Rusty, thanks alot!!! I would prefer not to leave this up |
Lo-Fi Version | Time is now: 27th April 2024 - 04:01 PM |
