Parking brake lever removal, What am i not seeing? |
74ravenna |
Feb 17 2018, 02:22 PM
Member Group: Members Posts: 471 Joined: 19-October 14 From: nh Member No.: 18,032 Region Association: North East States |
I'm having trouble removing my parking brake handle.
I've removed the clip from the pin that holds the cable but i can remove the pin (screw?) Does it pull out or unscrew? Also, how do i remove the bolt that holds the Brake Lever to the long? Its flush to the lever so there's no way for me to put a wrench or socket to it? It looked like it was going to be an easy thing to do! Even Haynes makes it sound like a super easy thing. What am i not seeing? Thanks. |
rgalla9146 |
Feb 17 2018, 04:10 PM
Advanced Member Group: Members Posts: 4,547 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
I'm having trouble removing my parking brake handle. I've removed the clip from the pin that holds the cable but i can remove the pin (screw?) Does it pull out or unscrew? Also, how do i remove the bolt that holds the Brake Lever to the long? Its flush to the lever so there's no way for me to put a wrench or socket to it? It looked like it was going to be an easy thing to do! Even Haynes makes it sound like a super easy thing. What am i not seeing? Thanks. After the clip is off the pin should slip out. No ? ....rust.... soak it or heat it. If you tap on the pin be sure to put a visegrip on the back part of the handle to prevent damage. I'm not sure what you mean about the bolt being flush. Is the seat in your way ? Why can't you put a wrench or socket on ? |
GeorgeRud |
Feb 17 2018, 04:26 PM
The handbrake lever just rotates on the stub that’s welded onto the long and doesn’t come off. If you just pull or pry it towards the center of the car, it should just slip off. A bit of penetrating oil may help if it’s corroded in place.
74ravenna |
Feb 17 2018, 04:41 PM
Clip is off but pin doesn't move. I soaked it. I'll give it more time.
The interior is out of the car, so no seat issue. The bolt i spoke of holds the brake Handle to the long, but the hole that the bolt screws into is recessed, so the head of the bolt does not extend out of the Handle. |
GaroldShaffer |
Feb 17 2018, 05:34 PM
You bought another 914? Group: Benefactors Posts: 7,620 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
The bolt i spoke of holds the brake Handle to the long, but the hole that the bolt screws into is recessed, so the head of the bolt does not extend out of the Handle. (IMG:style_emoticons/default/blink.gif) Picture please |
74ravenna |
Feb 17 2018, 05:43 PM
The bolt i spoke of holds the brake Handle to the long, but the hole that the bolt screws into is recessed, so the head of the bolt does not extend out of the Handle. (IMG:style_emoticons/default/blink.gif) Picture please I was going to take one but i didn't have a camera so i'll take one tomorrow, but right now its dark out, the barn is closed up, snow is on it's way and i'm in the house with the cats and the pellet stove. |
bdstone914 |
Feb 17 2018, 06:17 PM
bdstone914 Group: Members Posts: 4,515 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
The bolt i spoke of holds the brake Handle to the long, but the hole that the bolt screws into is recessed, so the head of the bolt does not extend out of the Handle. (IMG:style_emoticons/default/blink.gif) Picture please I was going to take one but i didn't have a camera so i'll take one tomorrow, but right now its dark out, the barn is closed up, snow is on it's way and i'm in the house with the cats and the pellet stove. Yes remove the 13mm hex head bolt. The handle will stick on the pivot pin. I get a pickle fork between it and the long. pry and move the handle up and down to get it off the pin. The pins rust in and usually have to be driven out hold it in a vise. Rarely have I been able to remove them while in the car. Easy way is cut the cable if you have a spare. Once you get the handle off of the pin you have some movement on the cable. If you can grind off the head of the pin in the bottom of the brake handle , pry the halves apart , you can separate the cable from the handle. I have spare cables if you go that route to cut it. Bruce |
74ravenna |
Feb 17 2018, 06:48 PM
The bolt i spoke of holds the brake Handle to the long, but the hole that the bolt screws into is recessed, so the head of the bolt does not extend out of the Handle. (IMG:style_emoticons/default/blink.gif) Picture please I was going to take one but i didn't have a camera so i'll take one tomorrow, but right now its dark out, the barn is closed up, snow is on it's way and i'm in the house with the cats and the pellet stove. Yes remove the 13mm hex head bolt. The handle will stick on the pivot pin. I get a pickle fork between it and the long. pry and move the handle up and down to get it off the pin. The pins rust in and usually have to be driven out hold it in a vise. Rarely have I been able to remove them while in the car. Easy way is cut the cable if you have a spare. Once you get the handle off of the pin you have some movement on the cable. If you can grind off the head of the pin in the bottom of the brake handle , pry the halves apart , you can separate the cable from the handle. I have spare cables if you go that route to cut it. Bruce Ok, good to know. I didn't think it was going to be that difficult but i'm happy to hear that it takes a little persuasion and cutting, i thought it was me. One question though, how many bolts hold the handle assembly onto the long? I have one bolt off, but there's another one that goes through the handle assembly. Its almost directly above the pin. thanks |
rgalla9146 |
Feb 17 2018, 07:26 PM
The bolt i spoke of holds the brake Handle to the long, but the hole that the bolt screws into is recessed, so the head of the bolt does not extend out of the Handle. (IMG:style_emoticons/default/blink.gif) Picture please I was going to take one but i didn't have a camera so i'll take one tomorrow, but right now its dark out, the barn is closed up, snow is on it's way and i'm in the house with the cats and the pellet stove. Yes remove the 13mm hex head bolt. The handle will stick on the pivot pin. I get a pickle fork between it and the long. pry and move the handle up and down to get it off the pin. The pins rust in and usually have to be driven out hold it in a vise. Rarely have I been able to remove them while in the car. Easy way is cut the cable if you have a spare. Once you get the handle off of the pin you have some movement on the cable. If you can grind off the head of the pin in the bottom of the brake handle , pry the halves apart , you can separate the cable from the handle. I have spare cables if you go that route to cut it. Bruce Ok, good to know. I didn't think it was going to be that difficult but i'm happy to hear that it takes a little persuasion and cutting, i thought it was me. One question though, how many bolts hold the handle assembly onto the long? I have one bolt off, but there's another one that goes through the handle assembly. Its almost directly above the pin. thanks There is only one bolt. It goes through the toothed piece. After the bolt is removed you have to get the handle to slide off the shaft that protrudes from the long. The toothed piece will come with the handle. There is a nylon bushing on the pivot shaft / handle. Apply WD 40 and work the handle up and down while levering it away from the long. |
74ravenna |
Feb 18 2018, 04:34 AM
Nice!
I hate to pry or force things without a clear understanding of how they work. Thanks all. |
Lo-Fi Version | Time is now: 7th May 2024 - 03:18 PM |
