Removal of A/C compressor, V-Belt location |
Chip |
Feb 22 2018, 01:26 PM
Member Group: Members Posts: 125 Joined: 1-April 17 From: Brigham City, UT Member No.: 20,986 Region Association: Intermountain Region |
Removing A/C unit from 914,1.8. It's for sale. Has the condensor, console controls, drier, some hoses, compressor.
Not sure where to re-route the belt from alternator. I think it just goes back to the fan. Any ideas? This compressor (York) is easily accessible from the bottom. |
mgphoto |
Feb 22 2018, 01:55 PM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
AC compressor runs off a pulley behind the cooling fan.
There is a spacer and the pulley, the passenger side cooling tin is usually cut to allow the belt to pass through to the pulley. The fan shroud needs to be removed to install the pulley. |
dr914@autoatlanta.com |
Feb 22 2018, 04:46 PM
914 Guru Group: Members Posts: 7,864 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
don't do it leaves too many holes, right front sheet metal needs to be patched and you lose 1500 dollars value
Chip |
Feb 23 2018, 11:39 AM
Lo-Fi Version | Time is now: 17th May 2024 - 08:26 PM |
