Whats this rectangle hole for? |
simonjb |
Feb 25 2018, 01:28 PM
KiwiMan Group: Members Posts: 563 Joined: 18-October 16 From: Stamford, Connecticut Member No.: 20,505 Region Association: North East States |
Can someone tell me what goes in/through the rectangle you see here in the engine tin??
Spoke |
Feb 25 2018, 01:57 PM
Jerry Group: Members Posts: 6,986 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
If the hole isn't blocked off it should be to stop the cooling air from escaping to the engine compartment instead of going past the cylinders.
McMark |
Feb 25 2018, 04:25 PM
If the hole isn't blocked off it should be to stop the cooling air from escaping to the engine compartment instead of going past the cylinders. This hole doesn't enter the cooling air section of the tin. It just passes from the bottom to the top. So, plugging it will stop hot air from travelling up from underneath, but I'd hardly be concerned with that amount of air. Leaving it open shouldn't affect anything. |
r_towle |
Feb 25 2018, 05:04 PM
Custom Member Group: Members Posts: 24,584 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
If the hole isn't blocked off it should be to stop the cooling air from escaping to the engine compartment instead of going past the cylinders. This hole doesn't enter the cooling air section of the tin. It just passes from the bottom to the top. So, plugging it will stop hot air from travelling up from underneath, but I'd hardly be concerned with that amount of air. Leaving it open shouldn't affect anything. Considering it’s right above the exhaust system, I would close it off so you don’t suck hot air from below. The rubber seal around the engine tin is not for looks, it has an engineered purpose. |
Lo-Fi Version | Time is now: 24th May 2024 - 04:44 PM |
