Engine Tin |
Engine Tin |
mmichalik |
Feb 25 2018, 03:16 PM
MikeM Group: Members Posts: 690 Joined: 27-January 16 From: Valley Center, CA Member No.: 19,600 Region Association: Southern California |
Hi Everyone.
I am gathering the last few pieces of engine tin for my car and I've got a question. I have a 1975 that started life as a 2.0. Before I got the car, the engine went it's separate way. I now have a 1910 (big bore 1800) that I believe is a 73 based on the serial number of the casing. That being said, I've noticed that tin for certain areas of the engine are based on production years. Is this due to changes on the car body/chassis itself or the type IV motor? i.e., should I be looking for these last few pieces of tin for the engine year or the body year? Mike |
Spoke |
Feb 25 2018, 03:31 PM
Jerry Group: Members Posts: 6,978 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
I think it has more to do with what size engine 1.7/1.8 vs 2.0. May have some differences between the years.
mihai914 |
Feb 25 2018, 03:38 PM
Senior Member Group: Members Posts: 800 Joined: 2-March 05 From: Montreal, QC Member No.: 3,697 Region Association: None |
I think it has more to do with what size engine 1.7/1.8 vs 2.0. May have some differences between the years. Yes kind of, the two main pieces that cover the motor will vary depending on the spark plug location of the heads. 1.7 & 1.8 stock heads use the same covers and 2.0 heads are different. All other pieces are interchangeable with only very small variations like extra holes. |
mepstein |
Feb 25 2018, 03:39 PM
914-6 GT in waiting Group: Members Posts: 19,248 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Larger changes betweeen engine size with smaller changes due to year. My suggestion is once you get the tin, fit it to your engine before you powdercoat.
rgalla9146 |
Feb 25 2018, 03:41 PM
Advanced Member Group: Members Posts: 4,545 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Hi Everyone. I am gathering the last few pieces of engine tin for my car and I've got a question. I have a 1975 that started life as a 2.0. Before I got the car, the engine went it's separate way. I now have a 1910 (big bore 1800) that I believe is a 73 based on the serial number of the casing. That being said, I've noticed that tin for certain areas of the engine are based on production years. Is this due to changes on the car body/chassis itself or the type IV motor? i.e., should I be looking for these last few pieces of tin for the engine year or the body year? Mike Both. 1.7, 1.8 , 2.0 + year of car and where the car was going to be sold. California (and ?) had emissions equipment that resulted in detail changes to the tin. Keep it simple, look for '73-'74 2.0 tin |
mmichalik |
Feb 25 2018, 04:18 PM
Thanks everyone, for the quick responses.
I'll look for 73 - 74 tin then. I only have 3 pieces left, all underside stuff. Mike |
Lo-Fi Version | Time is now: 1st May 2024 - 07:18 PM |
