2056 For Sale, Maybe |
Mblizzard |
Feb 26 2018, 07:37 PM
Advanced Member Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
I am switching out my 2056 with big valve heads and less than 5000 miles on the top with a 2.3. Bottom half has unknown mileage. If there is any interest in the long block I would sell it for $2000. The heads were over $1000. Still in Car and running if there is any interest.
Mblizzard |
Feb 27 2018, 07:29 AM
Some of the specifics.
Was standard 73 2.0 Engine # is GA 014782. Still has Stock FI Cam. To be clear, it does not have a dizzy because I am running Micro squirt which does not need a dizzy. Has all new seals in front and rear as well as Viton push tube seals. Heads came from Eric Shea of PMB and the top was built by Original Customs with new carefully checked 96mm AA pistons. All oil galley press in seals have been replaced with threaded plugs. Has Organic clutch and new pressure plate with the same 5,000 miles I can recheck the compression but last time I checked it was 130 to 135 across all cylinders. Checked because was losing power and it turned out that the throttle body plenum was cracked and creating a huge vacuum leak. I also have the complete D-jet FI that is completely operational and tuned for the 2056. |
Lo-Fi Version | Time is now: 17th May 2024 - 02:46 PM |
