GB for throttle cable improved $24 will be $32 after (pics post 153), These are on 6.19.19 Will honor GB price but after will be more |
Mikey914 |
Feb 27 2018, 10:47 PM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
We are looking at making an improved version of the throttle cable utilizing a thicker cable. We will be using the architectural cable we use in other applications. There has been some issue with fatigue on some of the cables currently on the market.
If there's enough interest we can easily make these with this more rugged cable. Who's in? |
Andyrew |
Feb 27 2018, 11:01 PM
EVERY carbed v8 conversion could use this.. The throttle cable has to be put to such a tight angle that they snap pretty often
Sadly I am drive by wire now so I cant use this... (IMG:style_emoticons/default/sad.gif) |
davehg |
Feb 27 2018, 11:03 PM
Member Group: Members Posts: 183 Joined: 19-September 17 From: PNW Member No.: 21,443 Region Association: Pacific Northwest |
If this works on a six conversion count me in
yellowporky |
Feb 28 2018, 12:50 AM
Member Group: Members Posts: 422 Joined: 18-October 09 From: Martinez, Ca. Member No.: 10,948 Region Association: Northern California |
i will take one for a stock injected car
Thanks |
Mikey914 |
Feb 28 2018, 02:28 AM
Mowog4 |
Feb 28 2018, 02:34 AM
Member Group: Members Posts: 285 Joined: 2-November 15 From: Mesa AZ Member No.: 19,325 Region Association: None |
I’ll take one
rmdinmd |
Feb 28 2018, 02:42 AM
Member Group: Members Posts: 488 Joined: 30-October 13 From: Greeneville,Tn Member No.: 16,585 Region Association: South East States |
in for one (IMG:style_emoticons/default/smile.gif)
Tbrown4x4 |
Feb 28 2018, 03:48 AM
Senior Member Group: Members Posts: 703 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None |
Me too.
sb914 |
Feb 28 2018, 06:05 AM
Surf Guru Group: Members Posts: 4,296 Joined: 25-November 12 From: Brookings,Oregon Member No.: 15,191 Region Association: Southern California |
I'll take two for v8
mgp4591 |
Feb 28 2018, 06:47 AM
914 Guru Group: Members Posts: 5,366 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
I'm up for one.
mb911 |
Feb 28 2018, 06:52 AM
914 Guru Group: Members Posts: 6,812 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I would be interested in 1 for a six as well.
wndsrfr |
Feb 28 2018, 06:59 AM
Senior Member Group: Members Posts: 1,428 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
VaccaRabite |
Feb 28 2018, 07:31 AM
En Garde! Group: Admin Posts: 13,425 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
How would this get routed? Will it use the stock route?
Does 1/8th inch cable mean the cable itself, or the cable and its sheath and all that? Will it have any internal lubrication to help with cable bind? Zach |
Mikey914 |
Feb 28 2018, 07:51 AM
For the 6 the routing will have to be determined. Since I don't have one. we will document.
The cable itself is 1/8" It can be lubricated, but will run on an internally lined sheath. I need to do some research as to the best lubrication for the materials involved, but will ship pre lubricated, and if it's the lubrication I think I can use should not require any additional maintenance applications. |
mb911 |
Feb 28 2018, 08:15 AM
For the 6 the routing will have to be determined. Since I don't have one. we will document. The cable itself is 1/8" It can be lubricated, but will run on an internally lined sheath. I need to do some research as to the best lubrication for the materials involved, but will ship pre lubricated, and if it's the lubrication I think I can use should not require any additional maintenance applications. I believe there is a way with a 6 to avoid the bell crank with a longer cable like the 4.. I think Terry had made some.. I need to research that a bit.. Ultimately I would love to carry a 6 cable on my website for a complete 6 conversion kit. |
Millerwelds |
Feb 28 2018, 08:25 AM
Pleepleus Group: Members Posts: 715 Joined: 24-June 08 From: Grass Valley, CA Member No.: 9,206 Region Association: Northern California |
I’m in. (IMG:style_emoticons/default/beerchug.gif)
bbrock |
Feb 28 2018, 08:39 AM
For the 6 the routing will have to be determined. Since I don't have one. we will document. The cable itself is 1/8" It can be lubricated, but will run on an internally lined sheath. I need to do some research as to the best lubrication for the materials involved, but will ship pre lubricated, and if it's the lubrication I think I can use should not require any additional maintenance applications. I believe there is a way with a 6 to avoid the bell crank with a longer cable like the 4.. I think Terry had made some.. I need to research that a bit.. Ultimately I would love to carry a 6 cable on my website for a complete 6 conversion kit. They have one for a six on their web site: http://www.terrycable.com/Throttle-cable-f...otor_p_303.html I'm interested in one for a carbed /4 but didn't see an answer whether installation would be plug and play for the stock item - at least as it runs through the tunnel from pedal to firewall. |
Mikey914 |
Feb 28 2018, 09:01 AM
One of my 4s is carbbed and using a stock cable. I can do 3 versions, dtock 4, a predetermined 6 conversion, and custom to customer spec. The 3rd bersion, will be more expensive if we do it in the future, but in production its easily accomidated.
76-914 |
Feb 28 2018, 09:09 AM
EVERY carbed v8 conversion could use this.. The throttle cable has to be put to such a tight angle that they snap pretty often Sadly I am drive by wire now so I cant use this... (IMG:style_emoticons/default/sad.gif) (IMG:style_emoticons/default/agree.gif) And there are enough of them to make it worthwhile. A cable for Subaru conversions would be nice as well. IIRC. the cable required for the Subaru is the same as stock except the sheathing is cut 6" shorter and cable was 6" longer. (IMG:style_emoticons/default/confused24.gif) |
bbrock |
Feb 28 2018, 09:11 AM
One of my 4s is carbbed and using a stock cable. I can do 3 versions, dtock 4, a predetermined 6 conversion, and custom to customer spec. The 3rd bersion, will be more expensive if we do it in the future, but in production its easily accomidated. Does anyone know if a longer than stock cable can be used on a carbed 4 to allow routing the cable through the stock location in the engine tin? It's been decades since I hooked up a throttle cable to carbs and don't remember how I did it, and I was less picky back then about how I did things. I'm completely ignorant about options and what a custom spec cable would look like for this application. |
Lo-Fi Version | Time is now: 26th April 2024 - 07:33 AM |
