Coil wires, Coil wires |
simonjb |
Mar 2 2018, 03:52 PM
KiwiMan Group: Members Posts: 563 Joined: 18-October 16 From: Stamford, Connecticut Member No.: 20,505 Region Association: North East States |
Just want to make sure I have all this connected correctly
Red from Distributor to Coil + Black from Distributor to Coil - Black with Purple (blue connector) to Coil - Black with Red (red connector) to Coil + Green wire you see unconnected to Temp sender White wire you see not connected - not used as running carbs |
simonjb |
Mar 3 2018, 01:08 PM
bump
jcd914 |
Mar 4 2018, 03:04 AM
Black with Purple (blue connector) to Coil - Black with Red (red connector) to Coil + These are the stock wires to the coil and you have them correct. The others are for an aftermarket ignition module and I don't know if they are correct or not. It depends on the module and how it is supposed to be wired. If I had nothing but the wire colors to go by I would wire it like it is. But I would first try to find out what module I had and research how that module should be wired. Electrical items are lousy things to guess about. Jim |
Lo-Fi Version | Time is now: 17th May 2024 - 03:25 PM |
