> GB limited quantity 20 sets only Cabin seal set $214, Tenitively 19 sets spoken for 1 left Invoices sent to all so far
Mikey914
post Mar 3 2018, 11:57 AM
The rubber man
Includes
Main Windshield top seal 91456303910
Lower main seal 91456331910
Roof to window seals
1 - 91453118510 - left targa top side seal
1 - 91453118610 - right targa top side seal
Vertical targa seals
1 - 91453114310 - left rollbar side seal
1 - 91453114410 - right rollbar side seal
#9 &28. 20 &36 in sets. With 14 as an option
Will include a copy of the factory maintenance manual to allow you to locate the adjustments for the door windows. I am working on installation instructions and techniques you can use to install these that will be available in about 9 days and can be emailed to you.
There is a re occurring theme that these seals are difficult to install correctly, and if not installed correctly will allow for more water to enter your cabin. This is my attempt to put together a kit in a format that will educate the installers as to what you need to do and not do at least from my experience. The 914 is prone to leaking, but lets minimize that to the extent possible. Will have option to purchase the OEM profile rear seal with the fuzzey for $42 (1/2 off) only with the kit.
https://900designs.zoeysite.com/914/914-cha...rts/811-00-roof
Mikey914   GB limited quantity 20 sets only Cabin seal set $214   Mar 3 2018, 11:57 AM
Mikey914   More   Mar 3 2018, 11:59 AM
mb911   More In for set..   Mar 3 2018, 12:54 PM
cn2800   One set for me, please!   Mar 3 2018, 04:57 PM
cn2800   One set for me, please! Oops. Plus #14 as w...   Mar 3 2018, 11:19 PM
rhodyguy   Wow.   Mar 3 2018, 03:09 PM
markhoward   I'm in for a set too.. +14   Mar 3 2018, 04:54 PM
Chris914n6   I was going to give you crap about slacking on the...   Mar 3 2018, 05:07 PM
Mercurial   Count me in...+14   Mar 3 2018, 05:23 PM
jet1   Please add me to the list +14 as well   Mar 3 2018, 06:12 PM
Flightpath   I will take a set with the option on #14   Mar 3 2018, 06:16 PM
carking1996   I'm in!   Mar 3 2018, 06:17 PM
plays with cars   I'm in for a set. +14 for me too. Point of cl...   Mar 3 2018, 10:28 PM
Mikey914   I'm in for a set. +14 for me too. Point of c...   Mar 4 2018, 04:12 AM
Daiberl   In for one set, + #14   Mar 3 2018, 11:32 PM
JamesM   Perfect timing. Count me in!   Mar 3 2018, 11:59 PM
jcd914   The timing is not great but I need these. I'm ...   Mar 4 2018, 01:20 AM
gus'914   I am in for a set plus 14, Thanks.   Mar 4 2018, 01:55 AM
98101   If there is a single raindrop or gust of wind, it ...   Mar 4 2018, 02:20 AM
Gary   I'll take a set, +14. thnx.   Mar 4 2018, 05:50 AM
billh1963   I'll take a set!   Mar 4 2018, 07:05 AM
914four   One kit please.   Mar 4 2018, 07:26 AM
Mikey914   PMs sent to all   Mar 4 2018, 01:28 PM
Shadowfax   One set please plus No. 14. Thanks!   Mar 4 2018, 01:42 PM
mb911   Paid already thanks.   Mar 4 2018, 01:51 PM
scallyk9   Add me please! I'll call in an order to in...   Mar 4 2018, 02:44 PM
warpig   put me down for one, and the throttle cable too. ...   Mar 4 2018, 06:28 PM
Mikey914   PMs sent to all one left. If you miss it and wa...   Mar 5 2018, 12:20 AM
maf914   I'll take one set of cabin seals. I will also...   Mar 5 2018, 07:36 AM
Mikey914   The cable will not be ready to ship out with thes...   Mar 5 2018, 10:42 AM
Shadowfax   Payment sent this morning. Thanks, Mark!   Mar 5 2018, 10:51 AM
mmichalik   PM sent   Mar 5 2018, 10:58 AM
Dougster   Put me in line for a set if someone drops out plea...   Mar 5 2018, 11:11 AM
cwpeden   Put me in line too! With #14   Mar 5 2018, 11:41 AM
Shadowfax   Got the seals today. Installed the rear Targa seal...   Mar 8 2018, 11:00 AM
Mikey914   Use a new break away blade knife knife and soapy ...   Mar 8 2018, 11:43 AM
Shadowfax   Use a new break away blade knife knife and soapy...   Mar 8 2018, 11:51 AM
98101   I am working on installation instructions and tec...   Apr 24 2018, 04:14 PM
Mikey914   Email sent. The trick is to install the upper corn...   Apr 25 2018, 12:21 AM
98101   Email sent. The trick is to install the upper cor...   Apr 25 2018, 02:21 AM
Mikey914   Heres some pics from my install. The rubber will ...   Apr 25 2018, 11:46 AM
Mikey914   Stary the inside edge   Apr 25 2018, 11:47 AM
Mikey914   Push in the edhe all the way down   Apr 25 2018, 11:49 AM
98101   Cutting the lower part to mate with the closing do...   Apr 25 2018, 09:03 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 12:38 PM
