Carb sizing |
Carb sizing |
73-914 |
Mar 3 2018, 08:24 PM
Senior Member Group: Members Posts: 575 Joined: 24-April 10 From: Albany UpstateNY Member No.: 11,651 Region Association: None |
Any thoughts on Dual 44 IDF instead of 40 IDF on 2056 motor with European Motorworks 054 106 H cam
type2man |
Mar 3 2018, 08:34 PM
Member Group: Members Posts: 353 Joined: 3-March 09 From: Miami, Fl Member No.: 10,127 Region Association: South East States |
Run 44's or better yet 40 or 45 dells, they run so much better and behave very well under all conditions....
Mar 3 2018, 09:51 PM
What's an "H cam"? Hydraulic? If so, you're not set up for big breathing anyway.
The 44s are likely overkill and will be harder to tune due to a weaker vacuum through the throat. You might pick up a little power at the top end with the 44s, but a mild cam keeps you from getting those anyway. --DD |
73-914 |
Mar 3 2018, 10:23 PM
What's an "H cam"? Hydraulic? If so, you're not set up for big breathing anyway. The 44s are likely overkill and will be harder to tune due to a weaker vacuum through the throat. You might pick up a little power at the top end with the 44s, but a mild cam keeps you from getting those anyway. --DD European Motorworks 054 106 H |
IronHillRestorations |
Mar 3 2018, 10:26 PM
No doubt, go with the 40's for a street car. Bigger isn't better.
Lo-Fi Version | Time is now: 17th May 2024 - 07:05 PM |
