Push rod tube seal leaks, sealant or not?? going to do mine second time and dont want leaks! |
DRPHIL914 |
Mar 7 2018, 10:05 AM
Dr. Phil Group: Members Posts: 5,766 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
I was very careful last time with this, followed the directions of the late Captn,
just used oil as lube and slipped them in place. some leak some don't, many say no sealant some have used RTV - looking for more advice so I don't have to do this again Phil |
DRPHIL914 |
Mar 7 2018, 10:17 AM
this is what I just got in, the Viton seals. I am hoping for a better result, the motor is out so it should be a lot easier to do this time around. Looks like I will then be doing the valve settings for the first time myself too so any advice would be good.
1adam12 |
Mar 7 2018, 10:39 AM
Member Group: Members Posts: 209 Joined: 25-May 17 From: Chino Hills, CA Member No.: 21,132 Region Association: Southern California |
this is what I just got in, the Viton seals. I am hoping for a better result, the motor is out so it should be a lot easier to do this time around. Looks like I will then be doing the valve settings for the first time myself too so any advice would be good. These are the references I used to do my valve adjustment. Pelican Tech Article https://www.pelicanparts.com/techarticles/9...alve_adjust.htm YouTube 'Type 4 Valve Adjustment' this is on a VW bus fyi https://youtu.be/thxE4Sroxm0 |
Lo-Fi Version | Time is now: 18th May 2024 - 11:34 AM |
