Push rod tube seal leaks, sealant or not?? going to do mine second time and dont want leaks! |
DRPHIL914 |
Mar 7 2018, 10:05 AM
Dr. Phil Group: Members Posts: 5,766 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
I was very careful last time with this, followed the directions of the late Captn,
just used oil as lube and slipped them in place. some leak some don't, many say no sealant some have used RTV - looking for more advice so I don't have to do this again Phil |
Elliot Cannon |
Mar 7 2018, 11:05 AM
Works fine. Lasts a long time. (IMG:style_emoticons/default/biggrin.gif)
Attached image(s) |
914_teener |
Mar 7 2018, 01:07 PM
914 Guru Group: Members Posts: 5,198 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Although Elliot is proud of this......the Captn would have some choice words. |
Mblizzard |
Mar 7 2018, 01:31 PM
Although Elliot is proud of this......the Captn would have some choice words. Choice indeed! The oil ring is a simple solution to a hugely complex problem. Keeping a good seal while tolerating huge thermal variances and pressure swings that occur inside an engine is a not a small feat. It only takes a small imperfection for this system to fail. But adding sealant (especially silicon) like the Dr. says is a bad idea as it just creates potential problems. If a small part breaks loose you would be very lucky if it made it to your oil filter. if it loges in a small oil passage or restricts oil flow you are in for some serious damage. I would rather replace the oil tube seals for leaking than an engine because I used the wrong sealant in the wrong application. |
914Toy |
Mar 7 2018, 01:49 PM
Senior Member Group: Members Posts: 718 Joined: 12-November 17 From: Laguna beach Member No.: 21,596 Region Association: Southern California |
Although Elliot is proud of this......the Captn would have some choice words. Choice indeed! The oil ring is a simple solution to a hugely complex problem. Keeping a good seal while tolerating huge thermal variances and pressure swings that occur inside an engine is a not a small feat. It only takes a small imperfection for this system to fail. But adding sealant (especially silicon) like the Dr. says is a bad idea as it just creates potential problems. If a small part breaks loose you would be very lucky if it made it to your oil filter. if it loges in a small oil passage or restricts oil flow you are in for some serious damage. I tried all the above. Eventually bought new tubes and with the above advice,installed them - success! I would rather replace the oil tube seals for leaking than an engine because I used the wrong sealant in the wrong application. |
Lo-Fi Version | Time is now: 18th May 2024 - 11:51 AM |
