Push rod tube seal leaks, sealant or not?? going to do mine second time and dont want leaks! |
DRPHIL914 |
Mar 7 2018, 10:05 AM
Dr. Phil Group: Members Posts: 5,766 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
I was very careful last time with this, followed the directions of the late Captn,
just used oil as lube and slipped them in place. some leak some don't, many say no sealant some have used RTV - looking for more advice so I don't have to do this again Phil |
Mblizzard |
Mar 7 2018, 11:26 AM
Advanced Member Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
I did this a couple of times. (IMG:style_emoticons/default/headbang.gif) But in addition to the Viton seals I learned that having everything perfectly clean is a must.
Probably does not help but I apply the seals to the tubes then freeze them. Minor reduction in size at best but they seem to go in extremely easy and I think reduces the chances for damage to the seals because you don't have to use as much force. |
Dave_Darling |
Mar 7 2018, 01:27 PM
914 Idiot Group: Members Posts: 14,986 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
DRPHIL914 |
Mar 7 2018, 01:57 PM
But in addition to the Viton seals I learned that having everything perfectly clean is a must. Clean and smooth--make sure there are no lips or nicks or ridges in the bores for the seals to snag on. --DD I think that since some leaked and some did not it was my installation or lack of proper installation that was the issue, I am hoping second time will result in no leaks - is crank case pressure and ventilation an issue or cause of leakage as well? |
Mblizzard |
Mar 7 2018, 02:06 PM
But in addition to the Viton seals I learned that having everything perfectly clean is a must. Clean and smooth--make sure there are no lips or nicks or ridges in the bores for the seals to snag on. --DD I think that since some leaked and some did not it was my installation or lack of proper installation that was the issue, I am hoping second time will result in no leaks - is crank case pressure and ventilation an issue or cause of leakage as well? There is always some pressure in the engine case due to blow by and the hurricane of pressure changes that occur every 180 degrees of rotation. Over time, these things take advantage of the small flaws in the seal like dirt or nicks and give birth to leaks. If you have enough pressure in the case to cause a well seated seal to fail then you have much more serious issues that need to be addressed!. (IMG:style_emoticons/default/blowup.gif) |
Lo-Fi Version | Time is now: 18th May 2024 - 10:49 AM |
