Push rod tube seal leaks, sealant or not?? going to do mine second time and dont want leaks! |
DRPHIL914 |
Mar 7 2018, 10:05 AM
Dr. Phil Group: Members Posts: 5,767 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
I was very careful last time with this, followed the directions of the late Captn,
just used oil as lube and slipped them in place. some leak some don't, many say no sealant some have used RTV - looking for more advice so I don't have to do this again Phil |
TheCabinetmaker |
Mar 7 2018, 06:31 PM
I drive my car everyday Group: Members Posts: 8,300 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Wether you use lube or sealant, when you reinstall; As the oring just starts to enter the case holes, rotate the tube as you gently push it in. That will keep it from getting pinched. Then make sure they are seated completely, and don't forget the wire tube retainers.
Lo-Fi Version | Time is now: 24th May 2024 - 03:44 AM |
