Double check first, new engine, new problems |
karmanbuilt |
Mar 8 2018, 12:24 PM
??? Group: Members Posts: 72 Joined: 7-July 08 From: Emmett, ID. Member No.: 9,262 Region Association: Pacific Northwest |
Started rebuild last September, not just a simple build. Dropped in motor after several set backs, and decided to eliminate the HE's for several reasons. Only to find out no way to bolt up cooling tins under the heads. Did I miss something, or is there a way I'm not seeing? At my age, I should be driving a golf cart instead of my 914!
Are the bottom cooling tins necessary to insure the engine doesn't run hot? Thanks to all who reply. (IMG:style_emoticons/default/driving.gif) |
mgphoto |
Mar 8 2018, 12:44 PM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Most important ones underneath are the ones that clip on the studs under the cylinders.
rhodyguy |
Mar 8 2018, 12:52 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,075 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
I take it you're referring to the warm air guides. They are NOT compatible with any version of headers that I'm aware of.
karmanbuilt |
Mar 8 2018, 12:56 PM
Mar 8 2018, 06:50 PM
914 Idiot Group: Members Posts: 14,982 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
They don't clip to the studs, they screw into the cylinder head and into the crankcase. They're up above the pushrod tubes (and have cut out sections that go above the tubes) pretty much tight against the cylinder fins.
It's very difficult to remove the head from the motor if you forget to remove those tins first. Don't ask how I know. (IMG:style_emoticons/default/wink.gif) --DD |
karmanbuilt |
Mar 8 2018, 08:17 PM
They don't clip to the studs, they screw into the cylinder head and into the crankcase. They're up above the pushrod tubes (and have cut out sections that go above the tubes) pretty much tight against the cylinder fins. It's very difficult to remove the head from the motor if you forget to remove those tins first. Don't ask how I know. (IMG:style_emoticons/default/wink.gif) --DD Thanks Dave for the heads up. I hope we're talking about the same tin. I attached a parts diagram with arrows pointing the tins in question. |
Spoke |
Mar 9 2018, 12:43 AM
Dave is not talking about the ones pointed to. He's talking about #5. I have HEs on my 914 but do not have the tins pointed to.
karmanbuilt |
Mar 9 2018, 10:57 AM
Dave is not talking about the ones pointed to. He's talking about #5. I have HEs on my 914 but do not have the tins pointed to. Hey thanks Spoke, this engine has just been rebuilt, and I wouldn't want those missing tins to burn up my work. I think I might have a plan to attach those tins to the motor.......or not. I'm not the best fabricator! |
rhodyguy |
Mar 9 2018, 11:13 AM
they are warm air guides up to model year 74' heat exchangers. Driver's side is Trans specific. Pass is generic. They attach to the case AND the heat exchangers. You might be able to weld tabs on your headers to put them on. Depends on how your header piping is configured. The ones for 75-76' HEs might be adaptable.
Lo-Fi Version | Time is now: 8th May 2024 - 03:53 PM |
