Double check first, new engine, new problems |
karmanbuilt |
Mar 8 2018, 12:24 PM
??? Group: Members Posts: 72 Joined: 7-July 08 From: Emmett, ID. Member No.: 9,262 Region Association: Pacific Northwest |
Started rebuild last September, not just a simple build. Dropped in motor after several set backs, and decided to eliminate the HE's for several reasons. Only to find out no way to bolt up cooling tins under the heads. Did I miss something, or is there a way I'm not seeing? At my age, I should be driving a golf cart instead of my 914!
Are the bottom cooling tins necessary to insure the engine doesn't run hot? Thanks to all who reply. (IMG:style_emoticons/default/driving.gif) |
mgphoto |
Mar 8 2018, 12:44 PM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Most important ones underneath are the ones that clip on the studs under the cylinders.
karmanbuilt |
Mar 8 2018, 12:56 PM
Lo-Fi Version | Time is now: 7th May 2024 - 03:24 PM |
