Double check first, new engine, new problems |
karmanbuilt |
Mar 8 2018, 12:24 PM
??? Group: Members Posts: 72 Joined: 7-July 08 From: Emmett, ID. Member No.: 9,262 Region Association: Pacific Northwest |
Started rebuild last September, not just a simple build. Dropped in motor after several set backs, and decided to eliminate the HE's for several reasons. Only to find out no way to bolt up cooling tins under the heads. Did I miss something, or is there a way I'm not seeing? At my age, I should be driving a golf cart instead of my 914!
Are the bottom cooling tins necessary to insure the engine doesn't run hot? Thanks to all who reply. (IMG:style_emoticons/default/driving.gif) |
rhodyguy |
Mar 9 2018, 11:13 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,073 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
they are warm air guides up to model year 74' heat exchangers. Driver's side is Trans specific. Pass is generic. They attach to the case AND the heat exchangers. You might be able to weld tabs on your headers to put them on. Depends on how your header piping is configured. The ones for 75-76' HEs might be adaptable.
Lo-Fi Version | Time is now: 7th May 2024 - 11:43 AM |
