Seat belt bolts, Which ones have collars |
Mowog4 |
Mar 8 2018, 10:53 PM
Member Group: Members Posts: 289 Joined: 2-November 15 From: Mesa AZ Member No.: 19,325 Region Association: None |
I am putting a set of seat belts in I purchased from seatbelt planet and I have a question on the receiver which bolts to the tunnel. Do they use shouldered bolts? All the shouldered bolts I have are a larger diameter, not sure if I should have them turned down or find different bolts.
Thanks |
rgalla9146 |
Mar 9 2018, 06:35 AM
Advanced Member Group: Members Posts: 4,552 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
I am putting a set of seat belts in I purchased from seatbelt planet and I have a question on the receiver which bolts to the tunnel. Do they use shouldered bolts? All the shouldered bolts I have are a larger diameter, not sure if I should have them turned down or find different bolts. Thanks Make contact with the supplier. Are the holes in the new belt hardware too small ? Serious issue |
76-914 |
Mar 9 2018, 10:06 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,501 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Don't know either but I'll be doing this as well in 8-10 days. I did ask Mike @ Seat Belt Planet about their hardware kit. He said theirs were 1/2" x 27thd bolts. No metric bolts were available from them. (IMG:style_emoticons/default/beerchug.gif)
theer |
Mar 9 2018, 10:19 AM
Senior Member Group: Members Posts: 676 Joined: 31-July 15 From: Dover, MA Member No.: 19,014 Region Association: North East States |
I'm not sure about the shoulder-bolt question, but the bolt size has been discussed at length here over the years.
The seat belt bolts are US sized 7/16-20 (apparently a US standard size required by law on all cars). They are not metric, although apparently an 11mm x 1.25 bolt is close enough that it also works. |
jmitro |
Mar 9 2018, 10:39 AM
Senior Member Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None |
I just installed their seat belts this past weekend. Yes, the receptacle hole is too small by about 1/16" and I had to drill it out. OTOH you could use as is if you want the receptacle rigidly fixed in place.
I emailed Mike at seatbelt planet and he said they were unaware but would make note for the future |
Mowog4 |
Mar 9 2018, 01:17 PM
I just installed their seat belts this past weekend. Yes, the receptacle hole is too small by about 1/16" and I had to drill it out. OTOH you could use as is if you want the receptacle rigidly fixed in place. I emailed Mike at seatbelt planet and he said they were unaware but would make note for the future I think I am going to get the shoulder machined down to fit the hole, I thinkk that will allow the movement while retaining the strength. |
warpig |
Mar 9 2018, 03:46 PM
Member Group: Members Posts: 290 Joined: 2-August 10 From: Portland OR Member No.: 12,002 Region Association: Pacific Northwest |
I went through this same process last week. I contacted them and the guy told me they only have one size hole and if you want a different size it will need to be drilled out. Not that big of a deal in the larger scheme of things. Just have to go buy the right size drill bit. (IMG:style_emoticons/default/dry.gif)
The customer service seemed good at seatbelt planet. I had called about another issue and after a little esplaining, a new set is on the way. (IMG:style_emoticons/default/piratenanner.gif) Hopefully in time for my first DE (IMG:style_emoticons/default/popcorn[1].gif) |
Lo-Fi Version | Time is now: 15th May 2024 - 06:49 PM |
