Let's see your ideas on gauges for your 914/6 conversion |
Tdskip |
Mar 9 2018, 09:29 AM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Modified center gauges?
Center console? Heads-up display? Synaptic wiring? What have you done that is functional and attractive? |
Mar 9 2018, 10:01 AM
914-6 GT in waiting Group: Members Posts: 19,269 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
John’s triple gauge kit that Timmothy assembled and added led’s. Can’t speak highly enough of Timmothy’s work.
He’s actually made me 3 sets so far and always donates a set to Octeenerfest. (IMG:style_emoticons/default/smilie_pokal.gif) Attached image(s) |
Tdskip |
Mar 9 2018, 10:08 AM
Very tidy.
My guess is that any later combo Gage up to 1989 would work, right? Oh, good morning by the way and thank you for the response. |
JmuRiz |
Mar 9 2018, 10:17 AM
914 Guru Group: Members Posts: 5,426 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
I'm doing the same setup as mepstein's
Anything pre 3.2 should work. If you have a 3.2 or 3.6 make sure to use that engine's tach. But be warned that you need to have matching gauge and sensor for the temp/pressure gauges. Sometimes if they are mis-matched they won't give an accurate reading. I have the tach that came with my engine, but not sure how to swap the silver button needle with the black one on the tach. I have a tach-adapt I can use if I can't figure it out. |
defianty |
Mar 9 2018, 10:25 AM
Senior Member Group: Members Posts: 659 Joined: 9-August 06 From: Essex, UK Member No.: 6,621 Region Association: None |
Here's my setup. The second picture shows my new Tacho.
(IMG:http://www.914world.com/bbs2/uploads_offsite/s6.postimg.org-6621-1520612758.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/s6.postimg.org-6621-1520612759.2.jpg) |
Tdskip |
Mar 9 2018, 10:58 AM
Thank you gentlemen. Nice work.
So as long as a source a 3.2 combination gauge and use OEM Sanders on the 3.2 engine I should be OK, right? |
raynekat |
Mar 9 2018, 12:49 PM
Advanced Member Group: Members Posts: 2,158 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
JOEPROPER |
Mar 9 2018, 01:04 PM
The answer is "no" unless you ask... Group: Members Posts: 1,184 Joined: 21-November 15 From: White Plains New York Member No.: 19,387 Region Association: North East States |
Mar 9 2018, 01:34 PM
Tdskip |
Mar 9 2018, 01:43 PM
Interesting
Mar 9 2018, 01:48 PM
I was mistaken when I once said you need to use a 3.2 tach with a 3.2 engine. An early tach will work fine and not damage the brain.
RickS |
Mar 9 2018, 10:03 PM
Senior Member Group: Members Posts: 1,408 Joined: 17-April 06 From: 'False City', WA Member No.: 5,880 Region Association: None |
RickS |
Mar 9 2018, 10:19 PM
Here's my setup. The second picture shows my new Tacho. (IMG:http://www.914world.com/bbs2/uploads_offsite/s6.postimg.org-6621-1520612758.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/s6.postimg.org-6621-1520612759.2.jpg) You can get a numeric oil temp overlay which I have added to my 911. It is first rate http://newvintageusallc.mybigcommerce.com/...odule-overlays/ |
burton73 |
Mar 9 2018, 10:48 PM
burton73 Group: Members Posts: 3,520 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
A nice element to having a 911 was having the Oil tank level gauge.
For guys doing 6 conversations it is nice to have if you have sensors in your oil tank. It is not super accurate but if you had a leak it would show a low tank if you look at it when not moving. They move all around and to get a good idea of the amount on the dipstick, stop and be on level ground. I have been with friends on the road and they have said they where a quart or 2 low just by reading their gauge. You get a feeling for it. I have one in my 6 from PO. Bob B |
Larmo63 |
Mar 9 2018, 11:42 PM
GeorgeRud |
Mar 10 2018, 12:32 PM
Maltese Falcon |
Mar 10 2018, 01:04 PM
Advanced Member Group: Members Posts: 4,641 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
If you're looking into non-analog, try the Haltech, seat belt warning is mandatory (IMG:style_emoticons/default/driving.gif)
patssle |
Mar 10 2018, 02:24 PM
Senior Member Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
Tdskip |
Mar 10 2018, 02:44 PM
Thanks for all of the ideas
scallyk9 |
Mar 10 2018, 10:56 PM
Member Group: Members Posts: 321 Joined: 16-October 16 From: Port Orchard, WA, USA Member No.: 20,499 Region Association: Pacific Northwest |
I was mistaken when I once said you need to use a 3.2 tach with a 3.2 engine. An early tach will work fine and not damage the brain. About two months ago when I ordered a Wong chip for my '87 3.2 w/Motronic motor, he asked me which tach I had and warned about using an early one. He didn't how early though and he didn't explain the potential problem with doing so. Since I already have a same year stock tachometer from a Carrera, I didn't ask. I don't understand the issue. |
Lo-Fi Version | Time is now: 14th May 2024 - 01:43 AM |
