Shelf Life of Auto paint, any idea? |
76-914 |
Mar 9 2018, 02:06 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,500 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I have some single stage Hot Rod Black for the engine grill and rocker covers that is 7 yr's old. Toss or OK to use. Garage stored @ 40F-95F. TIA, Kent
mgphoto |
Mar 9 2018, 02:25 PM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
I have some single stage Hot Rod Black for the engine grill and rocker covers that is 7 yr's old. Toss or OK to use. Garage stored @ 40F-95F. TIA, Kent Best to mix some up and try it on something as a test, I've been using a single stage black that is 4 years old as dated on the can without issues but it is a high quality PPG. |
Andyrew |
Mar 9 2018, 02:27 PM
I did some 5 years later but not 7. There is some stuff that supposedly displaces the air and works good for preservation, havent tried it.
I would spray some as a test. |
mgphoto |
Mar 9 2018, 02:52 PM
My 914 |
Mar 9 2018, 05:48 PM
Casual Member Group: Members Posts: 560 Joined: 23-April 16 From: Massachusetts Member No.: 19,928 Region Association: North East States |
7 years is a long time. Why take the risk on your car.
76-914 |
Mar 9 2018, 06:35 PM
7 years is a long time. Why take the risk on your car. Don't know if it is a risk yet. That's the purpose of this thread. I'll shoot one of the rocker covers if I don't receive any definite "NO's". I can sand and re-prep one of those in a jiffy. (IMG:style_emoticons/default/beerchug.gif) |
Rob-O |
Mar 9 2018, 07:57 PM
Senior Member Group: Members Posts: 1,252 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region |
Depending on who made it and what the base resin is you might be okay. Open and see what it looks like. Most likely has separated into resin (with metal flake if it was a metallic) and solvent. Solvent is really used to dilute the resin and make the mixture thin enough to spray. Check the viscosity. If it’s pretty close to what it was originally you’re probably good as that would indicate that everything was still in suspension. If it’s slightly thicker than originally thin it with solvent and give it a go. If it’s really thick toss it and start fresh.
Lo-Fi Version | Time is now: 13th May 2024 - 11:13 PM |
