oil recommendations? |
LCOX |
Mar 11 2018, 05:01 PM
Member Group: Members Posts: 93 Joined: 19-December 09 From: Pinnacle Member No.: 11,148 Region Association: None |
What oil do you recommend for my 914 daily driver? I use Castrol GTX 10/40 but have seen some posts that you shouldn't use any multi-viscosity oil less than 20/50 because of lower oil pressure at idle that may cause a flickering oil pressure light. I've also heard some people who use straight 40 weight or even straight 50 weight oil. What weight and brand is best for good oil pressure?
Rand |
Mar 11 2018, 05:08 PM
Cross Member Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
I like Brad Penn 20/50 green. These engines need zinc and phosphorous in the oil.
Wow, time flies, but I blogged this years ago after a bunch of research back then: http://www.randbaldwin.com/index.php/914-and-oils/ There may be some new changes now. |
ValcoOscar |
Mar 13 2018, 11:31 AM
Garage Life Group: Members Posts: 2,384 Joined: 19-November 13 From: SoCal Member No.: 16,669 Region Association: Southern California |
I like Brad Penn 20/50 green. These engines need zinc and phosphorous in the oil. Wow, time flies, but I blogged this years ago after a bunch of research back then: http://www.randbaldwin.com/index.php/914-and-oils/ There may be some new changes now. (IMG:style_emoticons/default/agree.gif) I also run Brad Penn 20/50 on my 914's...maybe different with a SIX |
cary |
Mar 13 2018, 07:08 PM
Advanced Member Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest |
I like Brad Penn 20/50 green. These engines need zinc and phosphorous in the oil. Wow, time flies, but I blogged this years ago after a bunch of research back then: http://www.randbaldwin.com/index.php/914-and-oils/ There may be some new changes now. (IMG:style_emoticons/default/agree.gif) I also run Brad Penn 20/50 on my 914's...maybe different with a SIX I too use Brad Penn 20-50. As does every air cooled engine that leaves Rothsport. |
RenoRoger |
Mar 13 2018, 07:39 PM
Member Group: Members Posts: 95 Joined: 11-November 10 From: Reno, NV Member No.: 12,370 Region Association: Northern California |
I like Brad Penn 20/50 green. These engines need zinc and phosphorous in the oil. Wow, time flies, but I blogged this years ago after a bunch of research back then: http://www.randbaldwin.com/index.php/914-and-oils/ There may be some new changes now. (IMG:style_emoticons/default/agree.gif) I also run Brad Penn 20/50 on my 914's...maybe different with a SIX I too use Brad Penn 20-50. As does every air cooled engine that leaves Rothsport. Who makes SUPERTECH 20W-50 sold at Walmart in 5 QT containers? The price is quite a bit lower than Valvoline VR 1 as an example. Is anybody using SUPERTECH? |
Lo-Fi Version | Time is now: 18th May 2024 - 03:01 PM |
