oil recommendations? |
LCOX |
Mar 11 2018, 05:01 PM
Member Group: Members Posts: 93 Joined: 19-December 09 From: Pinnacle Member No.: 11,148 Region Association: None |
What oil do you recommend for my 914 daily driver? I use Castrol GTX 10/40 but have seen some posts that you shouldn't use any multi-viscosity oil less than 20/50 because of lower oil pressure at idle that may cause a flickering oil pressure light. I've also heard some people who use straight 40 weight or even straight 50 weight oil. What weight and brand is best for good oil pressure?
Justinp71 |
Mar 13 2018, 10:18 PM
Senior Member Group: Members Posts: 1,583 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
I would use Brad Penn or if you want something cheaper Delo 400 LE. Careful there is another delo oil that Costco sells and that’s not the right one.
I would steer clear of gtx, I installed a new cam on my 3.0. Ran only gtx for 6 years, pulled the cam out and it had significant wear and I understand it’s mostly because of the low zddp. |
Lo-Fi Version | Time is now: 5th May 2024 - 04:22 AM |
