oil recommendations? |
LCOX |
Mar 11 2018, 05:01 PM
Member Group: Members Posts: 93 Joined: 19-December 09 From: Pinnacle Member No.: 11,148 Region Association: None |
What oil do you recommend for my 914 daily driver? I use Castrol GTX 10/40 but have seen some posts that you shouldn't use any multi-viscosity oil less than 20/50 because of lower oil pressure at idle that may cause a flickering oil pressure light. I've also heard some people who use straight 40 weight or even straight 50 weight oil. What weight and brand is best for good oil pressure?
Jamie |
Mar 14 2018, 11:38 AM
Senior Member Group: Members Posts: 1,025 Joined: 13-October 04 From: Georgetown,KY Member No.: 2,939 Region Association: South East States |
And I haven't seen any mention of Shell Rotella T 20W-50 that I thought used to be a recommended oil for our engines..It is SJ rated, and I don't have local sources for the Brad Penn, so is there an additive that would increase the desired zinc level in oils not up to the desired percentage of other oils?
Lo-Fi Version | Time is now: 5th May 2024 - 05:48 AM |
