oil recommendations? |
LCOX |
Mar 11 2018, 05:01 PM
Member Group: Members Posts: 93 Joined: 19-December 09 From: Pinnacle Member No.: 11,148 Region Association: None |
What oil do you recommend for my 914 daily driver? I use Castrol GTX 10/40 but have seen some posts that you shouldn't use any multi-viscosity oil less than 20/50 because of lower oil pressure at idle that may cause a flickering oil pressure light. I've also heard some people who use straight 40 weight or even straight 50 weight oil. What weight and brand is best for good oil pressure?
Dave_Darling |
Oct 23 2018, 01:25 PM
914 Idiot Group: Members Posts: 14,982 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Basically oils have changed a lot in the years since the 914 was engineered. It was pretty much a half-century ago; the engineering was done in the mid- to late-1960s.
You can run straight 30-weight in an unmodified engine if you want to. Make sure you use something with a decent amount of ZDDP in it. You can also run 20/50 oil if you want to. They should both work. Again, use something with a good amount of ZDDP in it. --DD |
Lo-Fi Version | Time is now: 5th May 2024 - 02:59 AM |
