WTB 5" Fog light retaining ring |
n2j2ryan |
Mar 15 2018, 10:38 PM
Member Group: Members Posts: 85 Joined: 9-January 17 From: Victoria BC Member No.: 20,740 Region Association: Canada |
Does anyone have the metal retaining ring that holds the lenses onto the housing. My good one has a little bolt that tightens the two ends, but the other one is held together with a piece of wire as the little L-bracket is broken off.
GaroldShaffer |
Mar 16 2018, 10:29 AM
You bought another 914? Group: Benefactors Posts: 7,620 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
Have a picture what you are needing?
I have the outer ring for the fog lights, but don't understand your comment about the L Bracket. Here is one of the many rings I have Attached image(s) |
n2j2ryan |
Mar 16 2018, 12:09 PM
Mine must be aftermarket. The ring looks similar, but is split, with a small screw to tighten. How are those held in place? Will take a pic tonight.
Blue6 |
Mar 16 2018, 12:33 PM
Senior Member Group: Members Posts: 1,033 Joined: 3-October 13 From: SoCal Member No.: 16,470 Region Association: Southern California |
What your describing sounds like after market. What yr is your car?
n2j2ryan |
Mar 16 2018, 12:38 PM
72. I will post a picture tonight
bdstone914 |
Mar 16 2018, 04:24 PM
bdstone914 Group: Members Posts: 4,512 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
The rings are different for the TN 12 and TN 4 lenses. Which lights do you have ?
Look for the marking on the lens. A picture of your might be helpful to see what you are describing. |
n2j2ryan |
Mar 16 2018, 06:16 PM
Lo-Fi Version | Time is now: 26th April 2024 - 06:56 PM |
