n2j2ryan
Mar 15 2018, 10:38 PM
Does anyone have the metal retaining ring that holds the lenses onto the housing. My good one has a little bolt that tightens the two ends, but the other one is held together with a piece of wire as the little L-bracket is broken off.
GaroldShaffer
Mar 16 2018, 10:29 AM
Have a picture what you are needing?
I have the outer ring for the fog lights, but don't understand your comment about the L Bracket.
Here is one of the many rings I have
n2j2ryan
Mar 16 2018, 12:09 PM
Mine must be aftermarket. The ring looks similar, but is split, with a small screw to tighten. How are those held in place? Will take a pic tonight.
Blue6
Mar 16 2018, 12:33 PM
What your describing sounds like after market. What yr is your car?
n2j2ryan
Mar 16 2018, 12:38 PM
72. I will post a picture tonight
bdstone914
Mar 16 2018, 04:24 PM
The rings are different for the TN 12 and TN 4 lenses. Which lights do you have ?
Look for the marking on the lens. A picture of your might be helpful to see what you are describing.
n2j2ryan
Mar 16 2018, 06:16 PM
Click to view attachment Click to view attachmentSomething like this. Bought LED lights, and trying to fit into the housings I had. No markings so they are not original.
