Gas Cap Advice, 1972 1.7 |
Ross |
Mar 16 2018, 12:36 PM
Member Group: Members Posts: 90 Joined: 17-August 16 From: Charlotte, NC Member No.: 20,304 Region Association: South East States |
Does anyone have any advice on a good gas cap? I have a 72 1.7. Whenever I make a left turn I smell gas. I know there are a couple of different ones out there. I think I need the metal one.
Thanks for any help, Ross |
jmitro |
Mar 16 2018, 12:52 PM
Senior Member Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None |
914rubber makes the seals:
https://shop.914rubber.com/914-Early-gas-ca...eal-914EGCS.htm but there are several other potential sources of leaks at the top of the tank so make sure you isolate the source correctly |
mepstein |
Mar 16 2018, 01:00 PM
914-6 GT in waiting Group: Members Posts: 19,245 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Yes, you need the metal one. There a 3 rubber seals at the top of the tank. Gas cap, Seal under the gas fill, seal under the gas gauge sender. I would take the time to replace all 3.
Ross |
Mar 16 2018, 01:28 PM
Thanks guys. I have replaced the snout seal and the seal for the fuel gauge sender. I think, based upon process of elimination that it is the gas cap. It's old.
On a side note - I kicked around whether I should test my process by putting rubber glove material (or some other kind of material) over the gas tank snout and then putting the gas cap on and see if I get the smell. Thoughts? |
GregAmy |
Mar 16 2018, 01:32 PM
Advanced Member Group: Members Posts: 2,268 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
Are you sure it's the cap? I had a problem with gas smell and some drips on left turns, especially when the tank was fuller, and it was rust holes in the tank on the rub strips against the firewall.
Ross |
Mar 16 2018, 01:36 PM
I think the tank is fine. It was a good used one I put in about a year ago. (But I know... w these cars anything is possible)
Lo-Fi Version | Time is now: 29th April 2024 - 10:25 AM |
