Front Trunk area needs assistance please, Are these parts available new or do I need to find a donor? |
BPic |
Mar 17 2018, 03:08 PM
Member Group: Members Posts: 341 Joined: 5-February 18 From: Miami, Florida Member No.: 21,864 Region Association: South East States |
Started gutting for my rebuild and found a couple of areas needing new metal. I can fabricate if needed but if these are available somewhere I would prefer to just buy them, preferably new. In the photo the highlighted area that hold the seal for the front trunk and, also highlighted and circled in red the area that mounts the front hood release. I have a feeling this is the second hell hole on the car based on where it is welding is gonna be an issue.
cary |
Mar 17 2018, 07:31 PM
BPic he's waiting for me to get back to working on Taylor's car and use the pieces on Taylor's trunk channels.
Based on my schedule for the next 6-8 weeks I won't be back on Taylor's car till May. Here's what Mark's had created. It was created primarily for the channels around the headlight buckets. If I were you I'd snag that piece Rich has offered up. If you don't take it I probably will take. Most cars have the issue your seeing in that left upper front trunk channel corner. The way they layered it it leaves a pocket under the old foam seal. As does the piece Rich offered. The channel corner I repaired on Doug's car somewhere close to the end. http://www.914world.com/bbs2/index.php?act...=2&t=249327 The trunk pull pocket is a real tough repair. I think I did it on one of Mark's car. Can't find it at the moment. I'll keep looking. That's a real tough place to work. |
76-914 |
Mar 18 2018, 08:18 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,505 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
BPic he's waiting for me to get back to working on Taylor's car and use the pieces on Taylor's trunk channels. Based on my schedule for the next 6-8 weeks I won't be back on Taylor's car till May. Here's what Mark's had created. It was created primarily for the channels around the headlight buckets. If I were you I'd snag that piece Rich has offered up. If you don't take it I probably will take. Most cars have the issue your seeing in that left upper front trunk channel corner. The way they layered it it leaves a pocket under the old foam seal. As does the piece Rich offered. The channel corner I repaired on Doug's car somewhere close to the end. http://www.914world.com/bbs2/index.php?act...=2&t=249327 The trunk pull pocket is a real tough repair. I think I did it on one of Mark's car. Can't find it at the moment. I'll keep looking. That's a real tough place to work. Shiny! What kind of material are those channels made from? Aluma-steel, galvanized or plain clean steel? |
mb911 |
Mar 18 2018, 08:34 AM
914 Guru Group: Members Posts: 6,855 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
BPic he's waiting for me to get back to working on Taylor's car and use the pieces on Taylor's trunk channels. Based on my schedule for the next 6-8 weeks I won't be back on Taylor's car till May. Here's what Mark's had created. It was created primarily for the channels around the headlight buckets. If I were you I'd snag that piece Rich has offered up. If you don't take it I probably will take. Most cars have the issue your seeing in that left upper front trunk channel corner. The way they layered it it leaves a pocket under the old foam seal. As does the piece Rich offered. The channel corner I repaired on Doug's car somewhere close to the end. http://www.914world.com/bbs2/index.php?act...=2&t=249327 The trunk pull pocket is a real tough repair. I think I did it on one of Mark's car. Can't find it at the moment. I'll keep looking. That's a real tough place to work. Shiny! What kind of material are those channels made from? Aluma-steel, galvanized or plain clean steel? Looks like cold rold to me.. |
cary |
Mar 18 2018, 06:54 PM
BPic he's waiting for me to get back to working on Taylor's car and use the pieces on Taylor's trunk channels. Based on my schedule for the next 6-8 weeks I won't be back on Taylor's car till May. Here's what Mark's had created. It was created primarily for the channels around the headlight buckets. If I were you I'd snag that piece Rich has offered up. If you don't take it I probably will take. Most cars have the issue your seeing in that left upper front trunk channel corner. The way they layered it it leaves a pocket under the old foam seal. As does the piece Rich offered. The channel corner I repaired on Doug's car somewhere close to the end. http://www.914world.com/bbs2/index.php?act...=2&t=249327 The trunk pull pocket is a real tough repair. I think I did it on one of Mark's car. Can't find it at the moment. I'll keep looking. That's a real tough place to work. Shiny! What kind of material are those channels made from? Aluma-steel, galvanized or plain clean steel? Looks like cold rold to me.. That would be my guess ............................... it's steel |
Lo-Fi Version | Time is now: 25th May 2024 - 12:43 AM |
