Rear Coil Over Shocks, What did I do wrong? |
FL000 |
Mar 18 2018, 09:23 PM
Member Group: Members Posts: 394 Joined: 31-January 12 From: Lancaster, CA Member No.: 14,076 Region Association: Southern California |
I am going to pull my rear coil overs later this week to see what I messed up, but thought I would ask for ideas in the meantime. Putting my car together after being apart for a really long time, and I noticed my rear coil over shock studs are pushing through the mount into the trunk way too far - so far that I can't tighten the nut enough to secure it. I am guessing my top hat is not stopping the shaft soon enough. A pic of my shock before installing is as seen. Note I have the top hat and first bushing below the shock support, and bushing, washer, and nut above the support (in the trunk). Am I missing something? Any insight would be appreciated.
Thanks! |
Amenson |
Mar 18 2018, 09:32 PM
That's opposite lock!! Group: Members Posts: 645 Joined: 27-May 05 From: Dublin, OH Member No.: 4,154 Region Association: None |
I am going to pull my rear coil overs later this week to see what I messed up, but thought I would ask for ideas in the meantime. Putting my car together after being apart for a really long time, and I noticed my rear coil over shock studs are pushing through the mount into the trunk way too far - so far that I can't tighten the nut enough to secure it. I am guessing my top hat is not stopping the shaft soon enough. A pic of my shock before installing is as seen. Note I have the top hat and first bushing below the shock support, and bushing, washer, and nut above the support (in the trunk). Am I missing something? Any insight would be appreciated. Thanks! It looks like you are missing the washer that goes between the top hat and the lower bushing. It sits on the step in the shaft and keeps the shaft from pushing though the bushings. |
FL000 |
Mar 18 2018, 10:17 PM
[quote name='Amenson' date='Mar 18 2018, 08:32 PM' post='2590223'
It looks like you are missing the washer that goes between the top hat and the lower bushing. It sits on the step in the shaft and keeps the shaft from pushing though the bushings. [/quote] Ok thanks for the tip. I’ll look for that when I take it apart (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 18th May 2024 - 06:55 PM |
