Rear Coil Over Shocks, What did I do wrong? |
FL000 |
Mar 18 2018, 09:23 PM
Member Group: Members Posts: 394 Joined: 31-January 12 From: Lancaster, CA Member No.: 14,076 Region Association: Southern California |
I am going to pull my rear coil overs later this week to see what I messed up, but thought I would ask for ideas in the meantime. Putting my car together after being apart for a really long time, and I noticed my rear coil over shock studs are pushing through the mount into the trunk way too far - so far that I can't tighten the nut enough to secure it. I am guessing my top hat is not stopping the shaft soon enough. A pic of my shock before installing is as seen. Note I have the top hat and first bushing below the shock support, and bushing, washer, and nut above the support (in the trunk). Am I missing something? Any insight would be appreciated.
Thanks! |
MarkV |
Mar 19 2018, 01:00 AM
Fear the Jack Stands Group: Members Posts: 1,493 Joined: 15-January 03 From: Sunny Tucson, AZ Member No.: 154 Region Association: None |
Those came off my stock Boge shocks and got re-used on Bilstein replacements. Not sure how it would work without them. They go on first ... on top of the blue aluminum piece in your photo. The bottom bushing goes on next and the top bushing goes on after the shock is in the car. The big washer bottoms out on the piece you are missing when you tighten the nut down.
Lo-Fi Version | Time is now: 18th May 2024 - 08:24 PM |
