Body Modification thought, Shaving the back of the lip off the rollbar? |
BPic |
Mar 25 2018, 03:31 PM
Member Group: Members Posts: 341 Joined: 5-February 18 From: Miami, Florida Member No.: 21,864 Region Association: South East States |
My first thought on this build was to restore to original. However the engine has been swap as well as the trans. (to a side shift so not to bad) With that info. I'm considering doing some slight modifications, engine upgrade etc. With regards to the body my thought was to eliminate the chrome trim around the roll bar and shave the lip around the roll bar. The reason is to just do a slight mod that not everyone would notice and keep it classy. Have any of you seen this done and if so what are the thing I need to watch for. I'm sure welding that area is gonna be touchy but I think it would look great in the end. (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/welder.gif)
See pic of were I'm thinking of. Any thoughts or comments would be appreciated. Sorry about the sideways shot. |
Rand |
Mar 25 2018, 03:38 PM
I shaved the targa lip on my last 914. It is indeed very touchy welding as it's thin. I enjoyed the project and loved the results, but it's meticulous.
BPic |
Mar 25 2018, 03:49 PM
Rand |
Mar 25 2018, 04:08 PM
I'm not sure if I have pics (IMG:style_emoticons/default/sad.gif) but I'll post if I find them.
Just be careful with the cutting because when you cut it flush it's easy to leave a bit of gap that's difficult to fill with weld. Do your best to minimize that gap (which is a balancing act between making the surface flat and cutting too much of the flange away). Use low heat tacks to close because it will want to melt holes. Grind flat and hopefully only a thin skim coat of bondo will be needed to make it perfect. |
Mar 25 2018, 04:16 PM
I'm pretty sure JP Stein did it early on, on his yellow auto x car. It is a lot of work to make it look nice.
Rand |
Mar 25 2018, 04:17 PM
A former old timer around here, JP Stein (who sadly is no longer with us) shaved his Targa on "the Shitbox" and there are pics here somewhere. I'll share if I find.
[edit: Funny timing Mark. I didn't see your post when I wrote mine.] |
914werke |
Mar 25 2018, 05:06 PM
"I got blisters on me fingers" Group: Members Posts: 10,066 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Keep in mind, removal of that seam & the trim that would have covered it across the top of the targa eliminates the area on which the rear targa SEAL rides. Or at the very least significantly reduces the seal area.
tygaboy |
Mar 25 2018, 05:51 PM
914 Guru Group: Members Posts: 5,292 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California |
This is Andy (Kreiger)'s car. I think it's a great looking mod.
Attached thumbnail(s) |
worn |
Mar 25 2018, 06:01 PM
can't remember Group: Members Posts: 3,156 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Mueller |
Mar 25 2018, 06:04 PM
Krieger |
Mar 25 2018, 06:17 PM
Advanced Member Group: Members Posts: 4,711 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
This is Andy (Kreiger)'s car. I think it's a great looking mod. (IMG:style_emoticons/default/agree.gif) hahahaha Thanks Chris! |
windforfun |
Mar 25 2018, 06:32 PM
Senior Member Group: Members Posts: 1,789 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
Why bother?
Andyrew |
Mar 25 2018, 06:51 PM
I did it on my car. Took a LONG time. I did it the long way around and its process is detailed in my thread. Probably took me 100hrs. If I did it again it would probably take me 20. Lots of cutting and welding and cutting and welding then grinding and welding and grinding... I did about 6 inches at a time.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i719.photobucket.com-626-1307840091.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i719.photobucket.com-626-1307840093.4.jpg) http://www.914world.com/bbs2/index.php?s=&...t&p=1427889 |
Rand |
Mar 25 2018, 06:57 PM
Andyrew |
Mar 25 2018, 07:24 PM
If you dont read my thread ill tell you. As you get to where the two pieces of metal come together there is another piece that will want to fall in (3 layers). Youll need to weld this in at least a couple takes.
The metal is super thin. I cut to 1/8" of the main metal then welded all around. Then ground it down in small sections to the exposed pieces in 1/4" incraments and welded. Repeat till done. Then grind and weld your hairline seams. The point where the fender meets the bar is difficult to get right. |
Rand |
Mar 25 2018, 07:29 PM
If you dont read my thread ill tell you. As you get to where the two pieces of metal come together there is another piece that will want to fall in (3 layers). Youll need to weld this in at least a couple takes. The metal is super thin. I cut to 1/8" of the main metal then welded all around. Then ground it down in small sections to the exposed pieces in 1/4" incraments and welded. Repeat till done. Then grind and weld your hairline seams. The point where the fender meets the bar is difficult to get right. Those thin layers are what makes it tricky to weld for sure. But such a fun project and I love losing the goofy trim bits. Not a mod for everyone, but rewarding if you want it. |
Krieger |
Mar 25 2018, 08:11 PM
If your good, it's done in a day. Chicks dig it!
n2j2ryan |
Mar 25 2018, 09:34 PM
Member Group: Members Posts: 85 Joined: 9-January 17 From: Victoria BC Member No.: 20,740 Region Association: Canada |
I have gone part way between. I removed the small trim piece at the top which was easy but then painted the rear trim pieces black. I have not got it back together but I really like the look.
bandjoey |
Mar 26 2018, 05:26 PM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Only 100 hours? (IMG:style_emoticons/default/smash.gif) d (IMG:style_emoticons/default/welder.gif)
Rand |
Mar 26 2018, 09:10 PM
I hear the envy so loud and clear. Freaking slackers. Real men do this. (IMG:style_emoticons/default/biggrin.gif) There are those who talked about it. And there are those who DID it.
Lo-Fi Version | Time is now: 17th May 2024 - 06:00 PM |
