FS: USED Boxster Hubs, 944 Turbo Stubs $124 shipped, For Those Wanting to Play. |
914Sixer |
Mar 25 2018, 08:40 PM
Here is the parts you need to play with at bargain prices. I pair of 944 Turbo stub axles with nut and washer. These are a perfect fit for the Boxster hub. They will require a spacer at the base to fill out the bottom to the wheel bearing. I was planing to use a OLD style German wheel bearing cut down for the spacer. I will include it with sale. You have to cut down or replace the rear wheel bearing holder. 944 or VW bus CV Joints are readily available.
Paypal: a914nut@email.com Attached image(s) |
Lo-Fi Version | Time is now: 19th May 2024 - 12:42 AM |
