Here is the parts you need to play with at bargain prices. I pair of 944 Turbo stub axles with nut and washer. These are a perfect fit for the Boxster hub. They will require a spacer at the base to fill out the bottom to the wheel bearing. I was planing to use a OLD style German wheel bearing cut down for the spacer. I will include it with sale. You have to cut down or replace the rear wheel bearing holder. 944 or VW bus CV Joints are readily available.
Paypal: a914nut@email.com
