This weekend's hard lesson learned, Conv'n guys don't let this hpn 2 you |
RON S. |
Jun 6 2005, 04:54 AM
9140430841, FINALLY RUNNING Group: Members Posts: 1,212 Joined: 22-May 03 From: WALTERBORO,S.C. Member No.: 724 Region Association: South East States |
This past weekend,was the time I was ready to put fire in the hole of my long term project.
Everything hooked up, (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) already to go (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) ,hit the key (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) ,and engine turns about 15 deg,and acts like it's locked up (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) . WTF. This can't be happening right.I checked every thing before hand. (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif) Engine is locked alright. (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) I can manually turn the engine around a small amount,and I can hear a metal to meatla contact,then dead stop. (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/ar15.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/ar15.gif) Talk about a man about to start crying after all this work and money.My thoughts are of internal motor problems.$$$$$$$$down the drain. I decide to remove the trans yesterday.now I can manully turn the flywheel.Tight as a tick,acts like rust cyl's. I remove the flywheel to try to get better leverage with a pry bar to turn the crank. What do I find you ask. (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) A "W" cast into the back of the flywheel sticks out far enough to dig into the webbing of the back of the case. (IMG:http://www.914world.com/bbs2/html/emoticons/mad.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/mad.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/mad.gif) Piss poor design on the part of the flywheel mfg.. I sanded the "W" down, w/a 4-1/2" grinder,and sanded some clearance in the case webbing. Guys',don't let this happen to you.Roll that engine over a couple full turns b4 you button it up for good. You'll save yourself a lot of grief and hurt feelings later. Ron Attached image(s) |
RON S. |
pic 2
RON S. |
Jun 6 2005, 04:55 AM
pic 3
RON S. |
pic 4
xsboost90 |
Jun 6 2005, 05:46 AM
Senior Member Group: Members Posts: 1,393 Joined: 2-August 04 From: cincinnati Member No.: 2,432 |
ouch. Glad you got it fixed!
redshift |
Jun 6 2005, 06:15 AM
Cap'n Krusty |
Jun 6 2005, 11:23 AM
IMO, there's something else wrong. I've NEVER run acroos that in 32 years of Pcar work. The Cap'n
Lo-Fi Version | Time is now: 17th May 2024 - 09:26 AM |
