This past weekend,was the time I was ready to put fire in the hole of my long term project.
Everything hooked up, already to go ,hit the key ,and engine turns about 15 deg,and acts like it's locked up .
WTF.
This can't be happening right.I checked every thing before hand.
Engine is locked alright. I can manually turn the engine around a small amount,and I can hear a metal to meatla contact,then dead stop.
Talk about a man about to start crying after all this work and money.My thoughts are of internal motor problems.$$$$$$$$down the drain.
I decide to remove the trans yesterday.now I can manully turn the flywheel.Tight as a tick,acts like rust cyl's.
I remove the flywheel to try to get better leverage with a pry bar to turn the crank.
What do I find you ask.
A "W" cast into the back of the flywheel sticks out far enough to dig into the webbing of the back of the case.
Piss poor design on the part of the flywheel mfg..
I sanded the "W" down, w/a 4-1/2" grinder,and sanded some clearance in the case webbing.
Guys',don't let this happen to you.Roll that engine over a couple full turns b4 you button it up for good.
You'll save yourself a lot of grief and hurt feelings later.
Ron
