Fiberglass rocker panel cover repair, Take two |
saigon71 |
Apr 11 2018, 04:00 PM
Senior Member Group: Members Posts: 1,999 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
I'm running fiberglass rocker panel covers. I like them, but I've had a problem with the mounting holes on the top breaking out at both the front and rear mounts in the fender wells. This is my 2nd attempt to fix the passenger side.
I realized that there wasn't a lot of meat left after the hole was drilled to keep the cover from vibrating and breaking the mounting hole. My previous attempt was to use fiberglass only to rebuild the area. This time around I cut thin strips of sheet metal to serve as fiberglass "rebar" on the outer section of the cover. I opened up the existing hole and sanded the top down. Next, I glued the "rebar" in place before using fiberglass cloth & resin on both sides of the area. Repainted the whole thing semi-gloss black. Installed it, marked where the holes needed to be and drilled fresh holes. Finally, I picked up some stainless steel screws and nut plates to attach the front & rear. It feels plenty strong and I'm pleased with how it turned out. |
Lo-Fi Version | Time is now: 22nd May 2024 - 08:22 PM |
