flywheel install questions |
nditiz1 |
Apr 13 2018, 01:39 PM
Senior Member Group: Members Posts: 1,188 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
Ok so after finding out I did not have the new o ring and felt washer I ordered them from pelican.
I installed them and following the pelican article I noticed the bearing was not flush in my flywheel it was protruding as much as the thickness of the felt washer. I'm not sure if that was the PO intention. I hammered it flush with the face that goes towards the crank, was this correct? Before installing the new rear seal I wanted to ensure the endplay was correct. I put the 3 washers back on and hand tightened, lightly tightened with a wrench 3 flywheel bolts. I get anywhere from Thanks all. |
Lo-Fi Version | Time is now: 23rd May 2024 - 11:51 PM |
