6cyl with turbo, could it be done.?? |
LongARM |
Jun 7 2005, 05:13 AM
it's better to burn-out , then it is to rust Group: Members Posts: 222 Joined: 6-March 05 From: Kingston Ontario Canada Member No.: 3,720 |
Has anyone ever done a corvair 6cyl in a 914.???
LongARM |
Jun 7 2005, 05:15 AM
with picture too...
LongARM |
Jun 7 2005, 05:16 AM
without spare tire...
xsboost90 |
Jun 7 2005, 05:30 AM
Senior Member Group: Members Posts: 1,393 Joined: 2-August 04 From: cincinnati Member No.: 2,432 |
sure it could be done, but would it be reliable and does the motor turn the right direction for the tranny?
ArtechnikA |
Jun 7 2005, 06:07 AM
911 transmissions are plentiful... donno exactly why you'd want a Corvair engine, if you wanted an air-cooled 6, but it's your car, do what you want. i'd rather see a properly engineered Corvair than a 911-engine hack job any day. |
tat2dphreak |
Jun 7 2005, 08:02 AM
maybe the type 4 doesn't leak enough oil for your taste? (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) just kidding, I'm sure corvairs can be made to not leak... but according to the 2 my dad had, the leaks came standard... IIRC the corvair spin backwards from our engines and you'd have to flip the ring (?) on the tranny, unless you WANT 5 reverse gears to go with the exxon valdez driveway... (IMG:http://www.914world.com/bbs2/html/emoticons/lol2.gif) |
ArtechnikA |
Jun 7 2005, 08:04 AM
911 transmissions come with the ring gear flipped standard... |
Joe Bob |
Jun 7 2005, 08:23 AM
Lot of extra work for only 180hp....you can get that with a stock 3.0.
LongARM |
Jun 7 2005, 06:12 PM
Thanx ...just wondering if anyone had.
yeah i remember the oil leaks too.. |
Air_Cooled_Nut |
Jun 7 2005, 06:14 PM
914 Ronin - 914 owner who lost his 914club.com Group: Members Posts: 1,748 Joined: 19-April 03 From: Beaverton, Oregon Member No.: 584 Region Association: None |
With enough money most engine swaps are possible (IMG:http://www.914world.com/bbs2/html/emoticons/welder.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/sawzall-smiley.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif)
LongARM |
Jun 7 2005, 06:28 PM
hmmmmm... unsafe at any speed.??
Joe Bob |
Jun 7 2005, 06:31 PM
Naders book was based on the premise that the early rear ends allowed the car to roll when over corrected in a panic manuever. His book killed the model even after GM upgraded the suspension. Kind of like the Ford Exploder...'cept today they have better spin doctors to counter the critics.... |
JWest |
Jun 7 2005, 06:51 PM
You can't turbo a 914-'vair...
ewdysar |
Jun 8 2005, 04:52 PM
What happens here, stays here. Group: Members Posts: 558 Joined: 29-October 04 From: Altadena, CA Member No.: 3,030 |
Nader's next book "Small on Safety" was basically the same book about VW's. Described the same swing axle design problems, published the same year that the car manufacturer switched to IRS, eliminated the major complaint, just like the Corvair. VW's had a lower incedent ratio, because lower HP kept the speeds around 75 mph, compared to the higher Corvair speeds.
On the plus side, he did put the fear of the press into the auto industry. They've responded with some design improvements, but more often better spin... (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) Eric |
redshift |
Jun 8 2005, 04:58 PM
Never a truer word spoken.
It's all spin. Everything has become spin. I like substance. M |
Dr Evil |
Jun 8 2005, 05:01 PM
Send me your transmission! Group: Members Posts: 23,000 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
I was in the process of doing this before I was given a Porsche 6. I still have the engine.
Here are the facts: -New viton seals make the engines less leak prone -you can easily purchase a reverse cam ( I have one) -they are much less expensive to maintain, buy, and rebuild. -easily modified. I am selling mine right now (not actively yet, but I will list soon). I have it boared out and modified to use stock 2.0 TI VW pistons and cylinders. This gives a 3.2 displacement and should putout a reliable 180hp with 190fp of tq. The only thing left to do is to put it together and put it in the car. The corvair engine is very similar to the TIV and, as such is easy to work on. Ask Aaron, he has seen half of my engine. |
Lo-Fi Version | Time is now: 20th May 2024 - 07:20 PM |
