Rear Trunk lid alignment, Need to get 2 more mm of movement > |
jim_hoyland |
Apr 16 2018, 11:12 AM
Get that VIN ? Group: Members Posts: 9,287 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I've gotten to the point where the rear trunk lid needs to go over 2 more mm to center it. If I widen the slot on the hinge where the bolts are currently located, it should give me the added space to move the lid.
Does this sound ok ? Attached image(s) |
McMark |
Apr 16 2018, 12:02 PM
You may try loosening the bolts and pushing the lid as far as possible in the direction you want it to go, then tightening them while holding pressure. This may do enough without modification.
SirAndy |
Apr 16 2018, 12:18 PM
Resident German Group: Admin Posts: 41,635 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
You may try loosening the bolts and pushing the lid as far as possible in the direction you want it to go, then tightening them while holding pressure. This may do enough without modification. (IMG:style_emoticons/default/agree.gif) There's easily 2mm you can get this way, simply push where you want it to be. (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 13th May 2024 - 02:12 PM |
