D-Jet ECU |
D-Jet ECU |
Bobco |
Apr 16 2018, 11:13 AM
Newbie Group: Members Posts: 35 Joined: 10-May 17 From: Butler pa Member No.: 21,091 Region Association: North East States |
Hi World
Will a D Jet ECU for a 2 Liter work for a 1.7 Liter Also dJet? Thanks |
JeffBowlsby |
Apr 17 2018, 05:12 PM
914 Wiring Harnesses Group: Members Posts: 8,490 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
The above post is confusing. This statement is not true that "There is no real feedback to the ECU from any sensors."
D-Jet is an "open loop" FI system, receives data (feedback) from its sensors and calculates pulse width to match demand based on that data. A "closed loop" system includes an O2 sensor(s) which additionally monitors exhaust gas characteristics to match demand and is more advanced than D-Jet. D-Jet cannot really be and is not intended to be 'tuned' per se. The components are 'fixed' to the average owner - its Plug N Play only - so the statement "Once you have assembled the correct collection of parts for a particular "year" than you will be able to tune the system making predictable adjustments" is also not a good characterization. The beauty of D-Jet is its simplicity and that as long as individual components, which can be individually tested, are good, the system works. No 'tune-ups' or alignments adjustments are needed other than the basic engine mechanical, fuel pressure, idle mixture and air mixture settings. |
mgphoto |
Apr 17 2018, 05:32 PM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
The above post is confusing. This statement is not true that "There is no real feedback to the ECU from any sensors." D-Jet is an "open loop" FI system, receives data (feedback) from its sensors and calculates pulse width to match demand based on that data. A "closed loop" system includes an O2 sensor(s) which additionally monitors exhaust gas characteristics to match demand and is more advanced than D-Jet. D-Jet cannot really be and is not intended to be 'tuned' per se. The components are 'fixed' to the average owner - its Plug N Play only - so the statement "Once you have assembled the correct collection of parts for a particular "year" than you will be able to tune the system making predictable adjustments" is also not a good characterization. The beauty of D-Jet is its simplicity and that as long as individual components, which can be individually tested, are good, the system works. No 'tune-ups' or alignments adjustments are needed other than the basic engine mechanical, fuel pressure, idle mixture and air mixture settings. Except if you modify your engine, but who does that! You are mistaking feed for "feedbacK" the sensors only feed info to the ecu, no date is feed back to the unit for modification of the signal, as you say it is basic but it can be "modified"or tuned for a specific engine. |
Lo-Fi Version | Time is now: 7th May 2024 - 02:41 AM |
