Door Stop Rebuild, After R&R both doors produce loud clicks upon opening |
North Coast Jim |
Apr 19 2018, 05:54 PM
Member Group: Members Posts: 323 Joined: 11-December 15 From: Northern Ohio Member No.: 19,450 Region Association: MidAtlantic Region |
Rebuilt both the door stops with 914 Rubber kits last year. Kits were from a purchase made in early 2017 IIRC, could be earlier. Doors open and close fine BUT both closures produce loud clicks upon closure of the door. Opening of the doors adds a loud pop to the clicks. Both are lubricated but no relief is found.
What I have noticed is the aluminum machined arms received have no vertical grooves where the wheels are to roll. The profile is smooth except for the closure stop points. I've looked at other door closures and this is the only difference I see - they have these vertical grooves. Anybody else has experience with these closures and can provide some input. Left an e-mail with Mikey but he must be flying or driving to Hershey. |
914Sixer |
Apr 19 2018, 08:55 PM
Problem is not the kit. The holes for the rod in the door post are usually wallowed out. Play with your door and I think you will see the problem. Thinking the posts need to be drilled for next larger size pin. Got to remember these were cheap, throw away cars.
Lo-Fi Version | Time is now: 16th May 2024 - 11:25 PM |
