Door Stop Rebuild, After R&R both doors produce loud clicks upon opening |
North Coast Jim |
Apr 19 2018, 05:54 PM
Member Group: Members Posts: 323 Joined: 11-December 15 From: Northern Ohio Member No.: 19,450 Region Association: MidAtlantic Region |
Rebuilt both the door stops with 914 Rubber kits last year. Kits were from a purchase made in early 2017 IIRC, could be earlier. Doors open and close fine BUT both closures produce loud clicks upon closure of the door. Opening of the doors adds a loud pop to the clicks. Both are lubricated but no relief is found.
What I have noticed is the aluminum machined arms received have no vertical grooves where the wheels are to roll. The profile is smooth except for the closure stop points. I've looked at other door closures and this is the only difference I see - they have these vertical grooves. Anybody else has experience with these closures and can provide some input. Left an e-mail with Mikey but he must be flying or driving to Hershey. |
Bartlett 914 |
Apr 20 2018, 02:16 PM
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
I had the same problem. The pin hole on the body of the car is worn out. Go to .250" pin. Just enough larger to fit. It is a little difficult because of the room needed to turn a drill or reamer but this is what you need to do
North Coast Jim |
Apr 20 2018, 07:14 PM
I had the same problem. The pin hole on the body of the car is worn out. Go to .250" pin. Just enough larger to fit. It is a little difficult because of the room needed to turn a drill or reamer but this is what you need to do That may be part of the fix as i see the aluminum arm being moved about the pin at the body when the door is opened/closed. I'll work on that next. |
Lo-Fi Version | Time is now: 17th May 2024 - 04:00 AM |
