Door Stop Rebuild, After R&R both doors produce loud clicks upon opening |
North Coast Jim |
Apr 19 2018, 05:54 PM
Member Group: Members Posts: 323 Joined: 11-December 15 From: Northern Ohio Member No.: 19,450 Region Association: MidAtlantic Region |
Rebuilt both the door stops with 914 Rubber kits last year. Kits were from a purchase made in early 2017 IIRC, could be earlier. Doors open and close fine BUT both closures produce loud clicks upon closure of the door. Opening of the doors adds a loud pop to the clicks. Both are lubricated but no relief is found.
What I have noticed is the aluminum machined arms received have no vertical grooves where the wheels are to roll. The profile is smooth except for the closure stop points. I've looked at other door closures and this is the only difference I see - they have these vertical grooves. Anybody else has experience with these closures and can provide some input. Left an e-mail with Mikey but he must be flying or driving to Hershey. |
Mikey914 |
Jun 30 2018, 10:51 PM
The rubber man Group: Members Posts: 12,668 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
We actually went through painstaking detail to reproduce these in the same tension as the OEM when new.
Popping from our experience has been two different issues that are related The 1st is the pin at the frame has some play, the springs at full force will actually pop the arm as the rollers move across the humps. The popping is slow allowing the pin to shift. Perhaps we should make some new pins too (IMG:style_emoticons/default/biggrin.gif) I’ll add them to the list.. (IMG:style_emoticons/default/biggrin.gif) |
n2j2ryan |
Jul 1 2018, 12:01 AM
Member Group: Members Posts: 85 Joined: 9-January 17 From: Victoria BC Member No.: 20,740 Region Association: Canada |
I'll take two pins!
Lo-Fi Version | Time is now: 16th May 2024 - 09:23 PM |
