Beautiful Day until..., Guess it was time though.. |
MartyYeoman |
Apr 21 2018, 07:09 PM
Senior Member Group: Members Posts: 1,519 Joined: 19-June 03 From: San Ramon, CA Member No.: 839 Region Association: Northern California |
Trans-axle go boom! (IMG:style_emoticons/default/headbang.gif)
Guess I'm looking for a transmission rebuilder. Any recommendations in the SF Bay Area? (IMG:style_emoticons/default/confused24.gif) Looking to get it up and running before the WCC. Attached thumbnail(s) |
Dr Evil |
Apr 23 2018, 08:55 AM
Send me your transmission! Group: Members Posts: 23,000 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Dang, that's a real bummer. Thanks for the recommendations, fellas (IMG:style_emoticons/default/smile.gif)
Since it is out, you can pull the side cover and see if you have a pinion head. 19mm bolt to get flange off, then some 13mm nuts and tap it off. I see you drained it already, that is a must. As for repair, definitely take member up on loaner transmission. This will keep you active and save you $$ in the long run. I have had to repair some of the ones done in the LA area by some shops, just FYI. If your pinion is toast, you will need a good used set and rebuilding with that will add $$$. I will guarantee that I can fix it and do it for less, including shipping. Hit me up if you are interested. Please post pics of what you find. |
Lo-Fi Version | Time is now: 21st May 2024 - 12:31 AM |
