Uncharted Territory, Clutch Replacement |
loco914 |
Apr 21 2018, 09:13 PM
Thy wheels have left the rail... Group: Members Posts: 45 Joined: 1-April 10 From: Amarillo, TX Member No.: 11,542 Region Association: None |
GeorgeRud |
Apr 21 2018, 10:18 PM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
I think you got your money’s worth out of those parts as the pressure plate definitely is worn out and the springs gave up in the clutch plate. Don’t forget to take the chance to clean the engine compartment and engine while it’s out as it’s a lot easier than when it’s installed.
porschetub |
Apr 22 2018, 02:04 AM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
That's messy,don't often see a disk do that,have found weak loose springs before takes a bit for them to break away like that,any damage to the inside of the flywheel?.
Judging by the wear on the pressure plate I would say its on its second (and last) life,make sure you carefully inspect/measure flywheel to make sure it is suitable for resurfacing,post a pic of it that would help,good luck. |
Porschef |
Apr 22 2018, 06:23 AM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
Throw in some SS fuel lines while the engine's out.
loco914 |
Apr 22 2018, 12:12 PM
Here’s the flywheel. Plan to remove and have it checked out.
Other progress today: Learning that engine tin screws can be quite stubborn (IMG:style_emoticons/default/headbang.gif) |
loco914 |
Apr 22 2018, 12:41 PM
98101 |
Apr 22 2018, 01:42 PM
Michael in Seattle Group: Members Posts: 373 Joined: 7-October 17 From: Seattle, WA Member No.: 21,495 Region Association: Pacific Northwest |
Going to do my clutch (pushrod tube seals, rear main seal) also. I'm learning a lot from these photos.
Best to drop the engine too? |
loco914 |
Apr 22 2018, 03:59 PM
Going to do my clutch (pushrod tube seals, rear main seal) also. I'm learning a lot from these photos. Best to drop the engine too? I dont know if it’s best or not as I figured on pulling both to check a few things out. (aka risk falling into the “while I’m in there” rabbit hole) SS fuel lines Find where all this oil is coming from Clean and powder coat tin Glad I did, hope to get it good and clean. Maybe air will actually move thru the thing an it will run cooler. |
loco914 |
Apr 22 2018, 05:04 PM
Ok. This is hopefully as far as I will go.
Having trouble confirming the source of all the oil on top as it is literally everywhere. Possibly coming from loose vacuum connections? Leak on the bottom is from my arch nemesis the taco plate. Pushrod tubes seem to be holding their own. Looking for thoughts on how best to clean all the crap off and out of the fins?? Can the oil cooler be cleaned or is it a lost cause? Thanks. |
rgalla9146 |
Apr 22 2018, 05:30 PM
Advanced Member Group: Members Posts: 4,545 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Ok. This is hopefully as far as I will go. Having trouble confirming the source of all the oil on top as it is literally everywhere. Possibly coming from loose vacuum connections? Leak on the bottom is from my arch nemesis the taco plate. Pushrod tubes seem to be holding their own. Looking for thoughts on how best to clean all the crap off and out of the fins?? Can the oil cooler be cleaned or is it a lost cause? Thanks. Some oil is over the tin, some under. I'd do OP switch, every seal on the oil filler tower and check the seals on the cooler. Make sure your crankcase is vented properly. Get the cheapest piece of 4' x 8' plywood and a gallon of mineral spirits and get busy with any brush you can find. The filth will transfer from the engine onto you. Find some plugs for the cooler and wash it with mineral spirits, it will come clean. |
nditiz1 |
Apr 22 2018, 05:38 PM
Senior Member Group: Members Posts: 1,180 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
Not trying to hijack, but can someone tell me how my clutch looks? Do I need to replace? Also flywheel?
(IMG:http://www.914world.com/bbs2/uploads_offsite/farm1.staticflickr.com-18763-1524440307.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/farm1.staticflickr.com-18763-1524440307.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/farm1.staticflickr.com-18763-1524440307.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/farm1.staticflickr.com-18763-1524440308.4.jpg) |
porschetub |
Apr 22 2018, 06:00 PM
Here’s the flywheel. Plan to remove and have it checked out. Learning that engine tin screws can be quite stubborn (IMG:style_emoticons/default/headbang.gif) Ok flywheel appears ok,any ridges you can feel on the surface with your fingernail generally means it will need to be refaced if still in spec. You can hit on the top the engine tin screws with a hammer and punch then use an impact tool on them ,if the slots are chewed out use some visegrips on them as a final solution. To clean the long block completely seal off the inlet/exhaust ports ,etc,buy lots of decreaser and brush it on with a wash brush,let it soak it then hose or waterblast off. If it was my engine I would take the cooler off after you have cleaned the block and have it ultrasonically cleaned,they get really dirty inside also. Do all seals on the engine "while in there" you will thank yourself later (IMG:style_emoticons/default/beer.gif) . |
IronHillRestorations |
Apr 22 2018, 07:16 PM
I. I. R. C. Group: Members Posts: 6,716 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
You are going to run much cooler with all the motor smeg cleaned off.
If you pull the flywheel make sure you use a Sabo seal. Don't score the seal bore or you can make an oil leak. You want a full flywheel package and replace the pilot bearing and felt washer too. The plate under the flywheel bolts is a one and done, so make sure you get one of those too. |
loco914 |
Apr 22 2018, 09:42 PM
Thanks for all the tips! Keep them coming. It may be a couple of weeks before I get some free time to work on it, but will post on any progress.
Dr Evil |
Apr 23 2018, 09:02 AM
Send me your transmission! Group: Members Posts: 22,995 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Don't forget the TOB and to see if you need to change the input seal to the trans since you are right there. Might as well check the output flange seals as well. The hard part has been done.
Andyrew |
Apr 23 2018, 11:55 AM
Spooling.... Please wait Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
Not trying to hijack, but can someone tell me how my clutch looks? Do I need to replace? Also flywheel? (IMG:http://www.914world.com/bbs2/uploads_offsite/farm1.staticflickr.com-18763-1524440307.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/farm1.staticflickr.com-18763-1524440307.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/farm1.staticflickr.com-18763-1524440307.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/farm1.staticflickr.com-18763-1524440308.4.jpg) Looks almost new. Steel wool the flywheel and pressure plate to remove rust on the friction surfaces, and brake clean on the clutch disk. |
loco914 |
May 5 2018, 06:55 PM
A little progress last night and today. Got the muck off all the engine tin and got some pieces blasted. Using medium glass beads and it seems to work well.
Thinking about painting the impeller housing any thoughts? Still a ways away as it doesn’t want to let go of 44 years of crap. Could blast as well, but figure it is too soft for glass. Would walnut shell media be good for this? (IMG:style_emoticons/default/confused24.gif) |
porschetub |
May 5 2018, 11:56 PM
A good clean on the housing you will be good,if you really prefer paint you have to clean more,total clean after prep with paint pre cleaner,heat it up a bit then apply etch primer let that dry for while (slow to dry) and apply few coats of Plasticote high temp wheel silver,its kind off a a mid gloss and looks great.
Get that shortblock cleaned right up,you have a nice looking car it all needs to be back in the engine bay ASAP (IMG:style_emoticons/default/beer.gif) |
Amphicar770 |
May 6 2018, 09:30 AM
Senior Member Group: Members Posts: 1,188 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region |
Fun stuff. Did mine about a year ago.
There are 1-tins that sit right against cylinders. Use high temp paint on those as powder coat could melt. If you get flywheel resurfaced, have them tell you how much they took off so you can use washers to adjust ball cup. One thing missed is gasket between oil filter mount and engine. If course that is where I have some seeping. Lots of good threads to follow including my own. People here are great at answwering questions as you go along. BTW, I replaced all if the awful cheese head tin screws with stainless he screws. |
Amphicar770 |
May 6 2018, 09:53 AM
Regarding oil cooler. They are not expensive. I got new one at busdepot.com (I went with genuine be part, they also sell aftermarket).
Here is my housing cleaned up and painted with Eastwood alumablast. http://www.914world.com/bbs2/index.php?sho...=279204&hl= |
Lo-Fi Version | Time is now: 5th May 2024 - 09:36 AM |
