Member Vendor, Who was it that made these ? |
jim_hoyland |
Apr 22 2018, 08:32 AM
Get that VIN ? Group: Members Posts: 9,278 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Years ago a 914World member made these and sold them in a group buy.
I’m trying to remember who that is ... Attached image(s) |
Mikey914 |
Apr 23 2018, 10:14 AM
The rubber man Group: Members Posts: 12,659 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I bought up a bunch of them and had plated to keep from rusting (the tie rod wrench) The problem I had was they were a little "soft" so I was not too happy about that. If McMark want to do up a run I'd be happy to distribute. i do have the tie rod one in stock $25.
-Mark |
Rand |
Apr 23 2018, 01:36 PM
McMark |
Apr 23 2018, 02:35 PM
The problem I had was they were a little "soft" You could heat treat them. Just get them red hot and quench them in oil or water to harden.I'm pretty sure the alloy of the metal has a lot to do with the potential hardness. Different alloys have different 'peak hardness'. You can only do so much to mild steel. |
Rand |
Apr 23 2018, 03:23 PM
The problem I had was they were a little "soft" You could heat treat them. Just get them red hot and quench them in oil or water to harden.I'm pretty sure the alloy of the metal has a lot to do with the potential hardness. Different alloys have different 'peak hardness'. You can only do so much to mild steel. For sure. I just assumed these were made of steel. What else would they have used? Even mild steel can be hardened. Disclaimer: I wasn't pitching the perfect solution, just discussing ideas about what you could try and might really work. |
Lo-Fi Version | Time is now: 11th May 2024 - 12:26 AM |
